Title pretty much says it all... where are they?
Thanks in Advance
Low beams are wired direct from bcm. High beam control relay is in the underhood fuse box which are "non-serviceable Printed Circuit Board (PCB) relays and are internal to the block".
Ok... so non serviceable relays on Headlights but are you sure about the BCM supplying ground to a 10-15amp load. That is just not a common electrical practice because I'm sure the IO on the BCM has to be is the sub 1 amp range or the BCM would be twice the size.
Thanks for the help
Check the ground schematic at GM Upfitters page. Lots of grounds on the body. I'd ground to chassis before putting that high a load thru the BCM.
Edited by spurshot
Allow me to rephrase it Low beams are powered by bcm directly. Rely is High beam only.
The headlamps may be turned ON in 3 different ways:
•When the headlamp switch is placed in the ON position, for normal operation
•When the headlamp switch is placed in the AUTO position, for automatic lamp control
•When the headlamp switch is placed in the AUTO position, with the windshield wipers ON in daylight conditions, after a 6 second delay
The BCM will also command the low beam headlamps ON during daylight conditions when the following conditions are met:
•Headlamp switch in the AUTO position
•Windshield wipers ON
•Vehicle in any gear but PARK
When the BCM commands the low beam headlamps ON, the vehicle operator will notice the interior backlighting for the instrument cluster and the various switches with backlighting control will dim to the level of brightness selected by the instrument panel dimmer switch.
The body control module (BCM) monitors three signal circuits from the headlamp switch. When the headlamp switch is in the AUTO position, all three signal circuits are open. When placed in the AUTO position, the BCM monitors inputs from the ambient light sensor to determine if headlamps are required or if daytime running lamps will be activated based on outside lighting conditions. When the headlamp switch is placed in the OFF position, the headlamp switch headlamps OFF signal circuit is grounded, indicating to the BCM that the exterior lamps should be turned OFF. With the headlamp switch in the PARK position, the headlamp switch park lamps ON signal circuit is grounded, indicating that the park lamps have been requested. When the headlamp switch is placed in the HEADLAMP position, both the headlamp switch park lamps ON signal circuit and the headlamp switch headlamps ON signal circuit are grounded. The BCM responds to the inputs by illuminating the park lamps and headlamps. When the low beam headlamps are requested, the BCM applies B+ to both low beam headlamp control circuits illuminating the low beam headlamp
Grounds to the frame near front body mount. Right and left respectivly.
Edited by tbarn
  • 4 years later...
I have a 2014 Silverado.  I installed LED light on the low beams and it worked fine.  I decided to purchase LEDs for my high beams.  I installed the DS and it worked fine.  Installed the PS, and it wouldn't work.  Also now my PS low beam will not work,  I replaced the PS LEDs with the OEM bulbs.  Nothing works on the PS only. I checked the fuse in maybe 26 under the hood.  3 prong 10 amp.  It was not blown.   Any ideas or suggestions?
Regards
Dan
  • 10 months later...
2015 Sierra 1500.  Just ran into the same issue, we went to see a late movie last night, when I started to drive home I noticed it was so dark so I pulled over and sure enough, both headlights were out.  I pulled the driver side bulb and it was fine, not burned out and today I tested the plug and it was showing 6v, yet no light.
My first instinct was the BCM but no one had one in stock so instead of doing nothing, I figured it has 70k miles and a new set of bulbs couldn't hurt.  Once I removed the air box and got to the passenger bulb I noticed the filament was gone, burned out.  I did that one first since it's kind of a pain to get to.  So....both had voltage yet the good bulb still did not work, yet replacing the bad one made them both work.  I don't understand how that is possible but, this was exactly the case... I tested everything twice to ensure I wasn't losing my mind.
Perhaps the good one only had voltage without a bulb in it is the only logical thing I can think of although I don't see how that's possible either, maybe the BCM just gets confused?  It still confuses me lol.
Spend 60 bucks on some LED's and save yourself the trouble and headache.
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
