Seat Covers with Dog
Just bought a 15 sierra and need to get seat covers as my lab will tear up the leather and get it dirty quick. Is there a good brand or material for dogs and dog hair?
Looking at carid for their coverkings or camotrucksests for their sportsman camo covers. Both are Realtree Max5
I've been considering covers from Mud River:
http://www.amazon.com/dp/B002CZLR12/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=VECIQG2SN6UQ&coliid=IFRU4LEK8JBE6
Why? Because they're good enough to be sold by LL Bean (where they offer a lifetime satisfaction guarantee). Yes, you'll pay more through Bean, but they're backed for life. I've read some really good reviews of how well they have held up to various "issues", too. :)
  • 3 weeks later...
I have a Rotti and GSD riding with me and it is pretty much hopeless trying to contain that disaster.....especially the GSD. But your on the right track with the camo as it hides the debris. I would also look for "hard" fine material that resists being embedded with hair.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
