Gmc a/c smell & cabin air filter
My 2014 will smell like a dead animal for about 4 minutes when it sits for 4 days. If it sits for less than that, no issues.
I already changed the cabin air filter once (at about 24/25k) and just attribute it to condensation sitting for a long time.
Does anyone have the tsb about the smell?
Frankly, I don't think they do me much good. My windows are down most of the time, even when it's hot.
Makes sense.
I just spoke with the Service Advisor, he informed me that they were able to duplicate my issue and indeed the condensation was not draining correct. They treated the evaporator with the foam and did a programming change on the HVAC system.....
Weird how most everything is serviced with some sort of software update or change these days.
I'd *really* like to know how software influences the condensate drain.
Perhaps it lets in less outside air even with recirc off. Less condensate to drain.
Just had this fixed on my 2015. They applied a coating to the coil and change the software to keep the fan running at a low speed to dry the coil after the engine is shut off.
Had my 14 SLE cabin air filter replaced two days ago and they got debris in the blower motor. Halfway through the fix today, the service writer doubted that was the cause of the weird noise, so I bet him a cup of coffee. HE BUYS!
If I want to replace the filter, how do I avoid doing the same thing?
  • 8 months later...
So I bought my 2015 1500 LT in November with 10k miles, I noticed then on occasion it would have a rank smell- and I attributed it to driving over something dead on the road. I live in KS and its cold so all winter I ran with the heat on- remote start etc. so it started warming up and i've notice the smell more. For a bit when I turn on the AC its bad, when I start it and its just vent only its putrid. I took it to the dealer ship today for an appt to have it looked at and they said they smelled something bad, but didn't really get to look into it today. They advised me to bring it back in next Monday, but they thought it was "probably something dead". I was like well normally things die decompose and stop smelling. So long as the heat is on its fine.... sounds like a cabin air filter to me. would this be a warranty thing?
  • 5 months later...
There's an "Afterblow" (I'm not making this up) function mentioned in some versions of the owner's manual. The purpose is to run the blower on outside air for ~10 minutes after shutdown in an attempt to dry off the evaporator. 10 minutes may or may not be long enough, especially if you're looking at 90+% RH. FWIW, I have not been able to find any evidence of this function in my truck, and have so far forgotten to ask the service people at my dealer if they know about it and what it would take to enable it.
I took my 2014 1500 for musty smell coming from vents two years ago. They did a software change that enables what you mention above. He didn't make it sound like it was something I could have enabled myself. I hear it run from time to time, not sure for how long... but I live in central MN, the battery is 3 years old, and never had an issue as far as that is concerned.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
