DIC Speed Limit Info page
Hey guys - was scrolling through settings today and turned not he speed limit info page. I have not yet taken it out to try it since I changed the setting, but what I thought was interesting is that on the info page it shows the white speed limit sign with km/h underneath. I know my settings are in US measurements and I double checked. Is this just the way it is, or should i expect that when I actually drive the truck it will change to mi/h? Thanks!
  • Replies 30
It gets it's info from the nav database. I'd expect it to change to the correct units when driven on a road for which the nav database has speed limit information.
Pretty sure mine displays the speed limit using whatever units I have selected in the dic.
(I still think in miles per gallon rather than L/100km, so I change it back and forth to suit my mood)
Anybody know how the implement this feature - it's crazy accurate. I'm talking about watching the speed limit change as you pass a speed limit sign. It's within feet of the sign. I'm just wondering how this info is encoded in the nav database. Anybody know?
I have a 2015 Sierra SLT with navigation, and I don't see a setting for speed limits. Is this a feature not available on my truck, or could it be that I need an upgrade to the software. I bought the truck a few weeks ago, but it was built 10/14. I drove it to a dealer an hour and a half from me this morning to get the headlights upgraded according to the TSB. I wish I had checked on other software upgrades before I made the trip.
You probably need to go under settings to add on that page to the DIC and also yes it pretty accurate I personally don't use it lol but it there cases u might not know the speed limit in a unknown area
I can't find anything in the settings that would allow me to do that. But my wife says I'm not very good at finding things. Any help in that direction would be appreciated.
Gusing the steering wheel controls on the right - go to settings, then info pages. There should be 12 total pages you can activate. Activate the one for speed limit. Hope that helps.
Thanks, toro....I found it after figuring out what Gmcant33 was referring to. I was looking in the settings on the Intelilink screen. It finally dawned on me when he mentioned DIC. I've had to Google a lot of abbreviations like DIC, BCM, etc.
Great that u found it have fun it's accurate by 10-15 feet like others mention.
  • 7 months later...
I haven't tried this out yet, but do y'all mean when you are driving along on the road there is a selection on the DIC that will show you the current speed limit where you are at ?
I know the Nav used to have a little speed limit sign on the screen that shows you that.....Have they basically moved that to the DIC ?
I thought on first glance a speed warning was just that....it would just let you know when you went over a certain speed.....sounds like it does much more ! ?
I had to idea I had more settings to access from the steering wheel! I found my display themes, speed limit, and everything else. thanks!
Looks like all that cool stuff would have been turned "on" by default....I was surprised at all that good stuff hiding too !
Please ignore the dirtyness! Eeek!. Love the speed feature and this theme. Sux to be doing 8 when the limit is 80 lol.
Sent From My Galaxy S6 Edge+
It gets speed limit info from the gps database -- but sometimes is wrong, or is off on the speed change location.
It's just a method to determine speed limit when you haven't seen a sign recently..
EDIT/CORRECTION: There is also on option that can be turned on to give a SPEED WARNING.
From manual:
Speed Warning : The Speed
Warning display allows the driver to set a speed that they do not want to exceed.
To set the Speed Warning, press p when Speed Warning is displayed, or press V on the main view to set the speed value. Press w or x to adjust the value. Press V to set the speed. Once the speed is set, this feature can be turned off by pressing V while viewing this page. If the selected speed limit is exceeded, a pop-up warning is
displayed with a chime."
(p, V, w and x are the 'arrow' symbols and check mark on the steering controls)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
