HMI Programming - what is needed?
vinsanity
I see a lot of people are choosing to pay $100-200 to send their HMI upgrade off to be programmed.
What is actually required to do the programming? Is it not something that can be purchased and done ourselves? I am considering upgrading my IO4 to an IO5 or 6, and can't seem to find any info online on how to do the programming myself. Is it an expensive system that is needed to do it? Just curious...
What is HMI, just curious... Thanks
Sent from my SAMSUNG-SM-N910A using Tapatalk
If you are talking about the unlock/video in motion/texting etc you don't do it yourself you have MVI do it for you.
That's exactly what I'm talking about. Can it not be done by anyone with a certain adapter or computer system? Why does it need to be sent to MVI or someone else to be done?
It needs to be sent to MVI because they are the sole supplier of the programming by design. It can not be done using an off the shelf computer or adapter etc.
To be clear MVI is the ONLY company in the world that offers the HMI unlock service.
You also can NOT do any programming yourself for any kind of upgrade on these systems...just FYI. This is all very specialized...even dealers have a hard time getting it correct :)
FYI....check out the new upgrades available for the I03 systems and there is not a dealer on the planet that will offer this :D
https://www.youtube.com/watch?v=PVS57N90YgI
Full length video will be available after purchase of the kit...call or text with questions!!
  • 1 year later...
I doubt anyone at MVI is gonna give you any insider tips but I don't see why you couldn't do it if you had enough exp and knowledge on the subject, or maybe if you are a straight hacker. Maybe not, just my take.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
No, you're right, it's do able but I can promise you the juice wouldn't be worth the squeeze or I would be looking in to it.
I believe the newer ones are running Linux, Id be interested in just understanding the process (even though I probably couldn't do it myself)
https://sourceforge.net/p/mylink-unlock-project/wiki/Home/
I found this .. only works to 14 it appears but interesting nonetheless
That is for a different platform. The issue isn't just the software but the communications protocols used to talk with the hardware to access the software. So say you figure out a way to effectively communicate on the GMlan or the MOST bus, you then have to figure out how to decipher the information that is being passed and what is primary and what is tertiary.
The source code is readily available, but getting all the pieces to fit is the insurmountable task and if it were cost efficient people would of figured it out. As it stands, this is what I do for a living, but my time comes at a high premium to the point where it's more economical to depend on guys like Chris and MVI who can do it because even if I invest the time to figure all of it out I'd never get a return on my investment as I wouldn't be able to provide the level of service that they do at an economical price. If I thought the prices they were asking were unreasonable it might give me incentive to do something but I happen to think they are reasonable and am glad someone provides the service.
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 799 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
