remote start
silveradosid
it was really simple, 2 screws to remove plastic panel under steering column, pull the plastic knob for tilt steering out and the lower plastic that covers the ignition pops right off giving you access to the ignition plugs. I do suggest getting the T harness , it makes this so easy. after installing T harness , splice one wire to obd plug and 1 wire to park light wire at the bcm . do the programming procedure and your done. there is a delay in starting because the units are programmed for diesel engines also.
  • 9 months later...
Is there a way to turn off this delay? I want the truck to crank the second the Fortin receives the start input.
