2014 Chevy Silverado power outlets
Mad Max
Does anyone know if any of the lighter or usb outlets power off after the vehicle is shut off? It seems to me that they all stay powered at all times. It would be handy to know which ones, if any, power down after the vehicle is locked.
All of mine power down with a delay. 2015
All mine on 2014 power down. There is a delay
"The vehicle is fitted with a 12 V accessory power receptacle. The accessory power receptacles are controlled by an ignition operated relay. The accessory power receptacles are operational when the ignition is turned to either the On or the Accessories positions. The X80J and X80K accessory power receptacles may be configured to be operational when the ignition is Off by changing the position of the 50A fuse from the F10DL position to the F11DL position in the left instrument panel fuse block."
The X80J and X80K outlets are the IP outlets.
