Polaris Expands Its Lineup with New ATV and UTV
John Goreham
10/6/2015
Polaris today announced two new vehicles. First, is the exciting new RZR XP4 family. The RZR is an extreme performance off-road ATV. The XP4 series now adds two additional seats so the vehicle can handle four people. The RZR XP 4 Turbo EPS offers 144 hp, power that is unmatched by any side-by-side in its class. Featuring a turbocharged engine with boost control and intercooling, the RZR XP 4 Turbo is paired with a PVT variable transmission to put the power to the ground is a way that makes the vehicle easy to master for drivers of all abilities.
The RZR XP 4 EPS High Lifter Edition has a 110 horsepower engine and a suspension that takes on the hardest off-road work. Dryseat technology paired with secure latching doors and sealed contact points around the rocker panel and front fender mean your ride is drier. The new RZR XP 4 line starts at under $26,000 and will be in dealerships this month.
Those looking for an affordable UTV should check out Polaris' new Ranger Crew 570-6 with seating for up to six. This hard-working UTV has a quiet, rear-mounted engine. Although value -priced the same rear adjustable suspension one finds on other Rangers is standard. Starting at under $12,000, the new Ranger 570-6 will be in Polaris dealerships by November.
Check out Polaris' website for prices and full specifications.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
