Short version of a long, sad story...... I need a cab brake light, or maybe even a block off plate that does not protrude rearward. Reason being, I just had a canapy installed, and the damn thing is sitting too far back. I can't move it foward enough to fit flush with the back, and not hit the brake light in the cab.
The canopy is a cab high unit made by Range Rider. It is their Apex Sport model that is suposed to have extended sides that cover the bed rail protectors. The fitment on this isn't great.
I've been surfing the net trying to find a different light, but having had much luck finding one with a side view that will show how flush it will fit the cab.
Gee that was an incredibly helpful response. How would you suggest I fix the canopy, sawzall? Just start hacking away on a $3000 painted fiberglass shell?
You're going to modify your $50,000 truck to get a piss-poor quality aftermarket piece to fit it? I don't understand the logic. Get the correct piece that fits the way it should. You already stated how the fit is not the best.......
Yeah I would contact the company and see why it fits so bad. A camper top made for a tuck should require no modification to fit.
If we're modifying the truck - 2 words - Duct Tape.
All sorts of color options, A tight secure finish.
Get the clear duct tape and keeps the lights for the Euro look. Or use red Tuct tape and still have the appearance of still having the brake light.
All I need is a different light or plate. The light can't even be seen. I hardly consider this "modifying" a 60k truck. Good grief..... Take a look at this light on your trucks. It must stick out a good 1.5".
If I could simply move the cap 3/8" foward, the fitment would be OK. Still not great but good enough.
I've been dealing with the dealer for five months and am worn out (screwed up a simple wheel and tire order too). Winter is here and I just want to be done with this.
It's a stretch... And not even sure where you could find it. Someone who has a 3D scanner and could 3D print you a cover? Just does not sound like something you can just buy, prob gonna have to fabricate it. And the machine shop of the time is a 3D printer.
Seriously now - just go to the dealer, or any dealer if yours is that bad, ask them about the third brake light delete plate. I know you could get it on the previous gens for the 3500s chassis cabs that had cube box conversions mounted or flush mount racks and service boxes. I'm sure the option would still be there.
Thank you! I had no idea there was a light delete option.
And to clarify, the shell was bought from a truck accessories shop, not the GMC dealer.
Maybe there was for previous generations, but nothing is showing as an RPO or SEO for the present truck. I don't know that I've ever seen one. Still seems odd your cap isn't designed to work around the stock lamp. Best of luck...
Are you sure the dealer order the correct canopy for the truck? You go to Range Rider website and they do list any canopy's for the K2XX platform. This could be the reason why it does not fit correctly.
Anything for the 2010-2013 trucks fits on the beds of the 2014+ trucks, the 2014+ truck bed for the short bed is only different than the 2010-2013 beds by about 1/2" in both directions. I wonder if your truck accessories dealer ordered a camper top for a 2010-2013 truck knowing that it would fit on the 2014+ truck.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
