Aftermarket headlights + hid kit for them.
  • Replies 31
any recommendation on some nice aftermarket headlights and also a hid kit to go with it? 2015 chevy LTZ z71
I hear good things about the anzos. Btw, if you do upgrade, id be interested in your oem projectors...
Before you completely bolt them on make sure you adjust them because you won't be able to once they are on. The screw to adjust up and down is behind them so put them on the truck, look what needs to go up/down, remove, adjust, repeat until you're satisfied.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
thanks!
just bought some anzos. now for a hid kit :P
Loaded my Anzo heads with HID Extra Razir led bulbs. Really happy with them
good in price ?
I thought so considering it includes everything you need including the canbus (was not needed). Plug and play no problems with our Silverado. www.hidextra.com
I also upgraded my fogs to a 25w hid kit from them in the 5202 size. Factory bulb was useless but I did not want to get carried away putting something that will build too much heat in that small housing as some experienced burning the reflector. 25w kit is more than enough for fogs and they still are safe for highway, not blinding other drivers.
TIp: if you go with my set up the led bulbs are 6000k color the hid fogs need to be the 5000k to be consistent color. Could be the Anzo's being projector or bulb difference . I was going to do yellow fogs but chickened out.
so how much was ur upgrade ? fogs/ highs/ lows ..$ if u dont mind me asking.
OP, did you sell your factory projectors?
i got some.
hey bud i went on the website i ordered hids highs/ lows/ fogs. the kit just comes with everything...208$ shipped to my door. H3 H7 5202
DROPKICK Edition
You running 55w or 35w in your Anzos?
I ran both. Currently running 35 because I have spare parts of those. 55 was really nice and brighter but I put that ballast on my brothers truck
DROPKICK Edition
DROPKICK Edition
And the 55's turned your Anzos burnt orange? J/k
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
