Garage floor mat
Aaron1085
How well does that hold up to "wrenching"? Looks awesome to park on and maybe do oil changes, but would a jack and jackstands destroy that?
You 'DO' know what you are getting into with that idea?
Exercise caution and realize jack stands can fail in all kinds of ways.......they could collapse, fracture, and they could even sink in the ground OR topple over. I have a stand that says not to support a vehicle by its side....just use a pair for either front or rear suspending. Some even say not to have all four corners in the air simultaneously.
I just want you to know you are kind of being a guinea pig when lifting on slopes (I used to do this alot), using unsure foundation such as soft ground, hot asphalt that can sink, broken concrete etc.....I have heard of using a 2X4 on the jack saddle to get the vehicle higher but I dont like the idea of interfering with the stands and their footing supports or the contact at the pawl/saddle. This is not a time to be careless or experiment.
For what its worth, and if the original poster is still looking, that G-Floor through Home Depot is OSHA approved for shop/industrial flooring. I have it in my mobile service trailer. I cut it with a razor knife and a bit of heat. I'm sure jack stands would leave an indention but it will most definitely hold up to some abuse.
  • 3 months later...
I have my garage coated with G-floor. I bought it through Homedepot.
The rolls I bought are 10x25 I believe.
FE7DE05B-571A-44E8-B7E9-1A38000186FC_zps
I like it. Is it floor panel?
