Whippled and looking for a cam
bh_performance
I have a 2014 GMC Sierra LT1 with the following mods:
- Whipple supercharger 2.9 (changed the pulley and boost at around 11 -12 pounds)
- Catted 17/8 headers
- Corsa Catback
I'm looking for a cam kit that will support the mods, the car currently has 530 RWHP, what can you suggest?
You can't handle 10 to 12 pounds of boost with out math injection and pistons
Basis for this statement? Seems to me he is already.
Without internal mods the 6.2 DI won't last with over 8 psi, at 11 to 12 psi method injection is a must 93 octan plus 12 psi a bomb waiting to explode.due some research
Its all in the tune. If the tune is safe he shouldn't have any problems. From what I have seen these motors have been holding up just fine to boost.
Did some research, here's what I found:
"method injection" - Looks like it is a coding term used by computer geeks. Not sure how it would benefit his truck....in fact, it might hurt it.
https://spring.io/blog/2004/08/06/method-injection/
"octan" - The gas company used by LEGO. Again, not sure how it would work with his truck. Then again, my LEGO's ran just fine with it. :dunno:
https://en.wikipedia.org/wiki/Octan
"due" - Adjective. Means owed or owing as a debt.
http://www.merriam-webster.com/dictionary/due
Sorry my secretary is busy, and spelling doesn't pay well. Bet you want to spank me
You keep on saying the same thing but you can't tell me why.
Is this something you have experienced yourself? Something you read somewhere?
What is your basis for this claim?
He is doing it, you're saying it can't be done. See the disconnect? I don't need to do any research past this thread to know it can be done.
And tuning is right, methanol injection is a band aid, and this comes from someone who has had two turbocharged cars running meth injection.
The Internet is full of people who are spouting opinions and until you can back your claim up another way other than just repeating it your claim doesn't hold water.
And hypereutetic pistons can handle boost, but not detonation, once again, tuning. I agree forged Pistons would be better, but I'm not going to say it won't work. Hell, I used to run 30 psi on cast iron apex seals if you want talk about things you shouldn't do.
Sounds like a nice set up. Have you taken it to the track? And speedometer acceleration vids? I run a tvs 1900 and a set of headers by american racing. I'm always looking for comparisons. My rwhp is a mere 450 but it seems to haul butt in the 1/4 mile.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
