FNG from California
SurFire
Hi everyone. I have been lurking for a couple weeks now and thought I would interduce myself.
I just recently bought a 2015 Sierra 1500 Z71. Coming from mostly older Toyotas and Volvos, I am liking this truck. I bought it for work and to have something new. I still like to tinker on my Volvos though.
I am from Central California, a small rural coastal "town" called Big Sur. Some might know of it, some might not. I caretake a large property here and also am a Captain with the local Vol. Fire Dept.
I have been an enthusiast of anything thatt has an engine and wheels since I can remember and have always liked tinkering on things. I'm slowly learning what I can about my truck and will probably start tinkering with it soon enough.
Anyhow, I have found tons of great info on this site, and seems like there are some pretty cool people around. I hope to learn more and get to know some of you. Thanks in advance for any help you give me and letting me be a part of this community.
- Jon
Welcome. I am Chris, the Community Manager here. There are helpful links pinned to the top of the new member area. I am from Bakersfield, Ca and we do put on a couple member's BBQ's a year up at Castaic Lake
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
