Salina here. Have you ever been to Crisis City SW of Salina to train?
Yessir! Trained there earlier this year. I'm a member of Kansas Task Force 2 from NE KS as a Communications Specialist.
Burlington.
Good deal! That makes four of us then. Topeka, Chapman, Salina and Burlington. We may have to get a shindig put together sometime.
  • 5 months later...
  • 3 weeks later...
  • 1 year later...
  • 3 months later...
  • 5 months later...
  • 4 weeks later...
