2015 Silverado 4.3 Spintech 6000 video
Gorske
Switch my exhaust up again. Went with a Spintech Pro Street 6000 3" in/out muffler with a 3" in 3.5" out tip. Let me know what you think.
Old setup MagnaFlow 3" in duel 2.5" out muffler with duel 3" tips.
New setup.
Sounds great for a v6, curious how v8 would sound. How is it in 4 cyl mode?
V8s with Spintech mufflers sound amazing! I have my 4 cylinder mode shut off for my custom exhaust by my tuner and I really didn't lose any mpg by doing it.
I had there short mufflers on my old 06 GTO and it sounded sick but was a true dual setup. Curious how a single exit would sound, good I'm sure just not sure how different it'd be. I want zero drone or helicopter sound in this truck. Tuning out isn't an option yet
Hard to avoid that with an aftermarket muffler with still having DoD on. :(
Yeah starting to accept exhaust may not be in the cards for awhile. I can keep it out of v4 by keeping it in M5 but don't know I want to take the mpg hit.
Sounds amazing. How much did your spintech setup run? I need this on my v6
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
Muffler was 81, 26 for shipping, 20 for the tip and 125 for a muffler shop to run all new 3" pipe from the flange and weld it up. So 252 total.
How's the drone?
Honestly not bad at all. I'd say less then the MagnaFlow and even the MagnaFlow wasn't much louder then stock on the inside of the truck.
Sounds great man. How much of the stock exhaust did you end up removing?
They used the stock 2.75" pipe from the flex pipe till about where the stock muffler would have been. From the Spintech muffler to the tip was new 3" stainless pipe.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
