2015 Silverado Leveling kit, Which One Is The Best?
Ok, so I asked the question about fitting a 275/70/18 on a stock Silverado. I recently bought a set of ko2 275/70/18 tires and later realized they rubs a little (not much) This don't worry me but there isn't much overall room in the fount wheel well.
So now I finally decided to buy a leveling /lift kit and I don't know which brand is the best? and No don't recommend rough country I knows you can buy it for $49.99. I was looking at buying a Ready lift?....any pros or cons?
Which is better lower or upper strut extensions?
Right now I trying to decide how big should I go. I was thinking a 2.25" and add lager block in the rear (that would be an inch) or should I go with a 1.5" or 1.75" and not touch the rear?
I Still wants a bit of a factory rake because I does some towing and uses the bed daily for hauling items.
Can someone help me here, I kind of needs to know soon because I wants to order some type of kit.
I have a top gun customz 2" level, front only. Solid steel, welded together, basically all kits are the same to tell you the truth. Mine looks like it sets level, but i think there is a tad bit of rake. Go with a 1.5" and you'll be fine.
I plan on putting in a 2" block in the rear to give a tad more rake for when im towing and hauling and such
What do you have a crew cab std box?? also what do you have upper or lower strut spacer?........ I thinking I am going to buy the 2.25" kit because its the same price as the 1.5" and I only install the top strut piece which is 1.5". in the future I put the lower strut spacer in and add an inch to the rear.
Mine is a under the strut spacer. Truck is a crew cab short box. Heard good and bad about a 2.5" level as far as steering and suspension components wearing out so i figured i would only do a 2"
Go with Bilsteins. Its all a single adjustable unit. No funky strut spacers on the top or bottom. Plus you benefit from having a premium shock installed.
A lift block is a lift block, they're all the same just made of different materials. Like fonduput said go with billstein 5100's.
Yeah I know that I wanted to know what is the best brand of a leveling kit.....
Bilsteins are a leveling kit.
Ill echo some of the others, from research on here and elsewhere. Only leveling kit I would use is the Bilstein 5100 leveling front strut.
If you do not want to spend the money on the Bilstiens, I would go with the Rough Country kit, or something similar.
This is the kit I got http://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html.
I called them up and switched out the 2" block that comes with the kit for a 3" block to retain some rake, only a few dollars more.
Just seems so pricey for 150, when the 5100s are what like 120ish a piece for level and a nice strut upgrade.
  • 3 years later...
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 2 Anonymous, 612 Guests (See full list)
