Kind of off topic but how much was your mpg affected by the cam swap? I'm assuming that cam has a much larger fuel lobe than stock.
After all the mods so far I get around 9mpg
Highway mpg about 22-25 not really sure
  • 6 months later...
Completed my flex fuel conversion recently. I installed the GM OE sensor and had BB tune it. Install was extremely easy. I started off with a 1/4 to verify operation, and currently have about a 3/4 tank of e85.
The truck already feels so much more responsive. E85 combined with BB ecm and tcm5 tune is a perfect combo! Total cost of conversion (not including BB AutoCal) was about $75.
Gas mileage is down between 16.5/17, but with e85 at $1.99 and 89oct at $2.35 around me, so it is slightly cheaper to run e85. I would highly recommend it?
The truck already feels so much more responsive. E85 combined with BB ecm and tcm tune is a perfect combo! Total cost of conversion (not including BB AutoCal) was about $75.
Gas mileage is down between 16.5/17, but with e85 at $1.99 and 89oct at $2.35 around me, so it is slightly cheaper to run e85. I would highly recommend it!
With your conversion, did you only replace the sensor or did you have to convert the fuel lines/hoses as well?
I am looking to convert my truck to e85 soon.
Jesse7, I ordered the conversion kit from Carl and I already had a tune being crafted for the ECM by another vendor when I bought the conversion kit. I believe the conversion kit will have all hardware needed for the conversion (per Carl's site) and then you just need your ECM tuned for the tables to be utilized with the e85.
$75? Seems really low when I add up the price of the parts in post #16. Can you clarify what you did?
Carl's kit looks to be the best route, but I'll wait to see what jetlife says above (considerable cost difference).
I finally went ahead and got the sensor and will be delivered today. I will be installing the sensor tonight, and if all goes well, tuning tomorrow. Excited to see what the outcome will be! currently I am pushing 340RWHP and I am expecting to see atleast 10-15HP gain.
Damn. Some nice numbers there. So factory numbers look like a 25% drivetrain loss. That sounds like a lot to me. For some reason i was thinking 15% was more like the norm.
15 to 18% is for manual transmissions and 20 - 25% for automatics
Sent from my SM-T817V using Tapatalk
You do realize that my post was almost 2 years ago?
After some issues with the post office losing my package, I finally got the sensor installed, turned on and tuned. Jumped from 340RWHP to 352RWHP. Definitely feel the power increase, I even feel like it shifts smoother than before. After 100 miles of driving, my city MPG went down from 15mpg to 11mpg, but with the price of e85 way lower than 93 octane gas, I feel like I'm saving a lot of money. Install was a breeze, got it done in about 45 minutes - 1 hour. Did not have to change any fuel lines or hoses. I simply cut the fuel lines, attached the sensor with 3/8 couplers, tune, and that's it!
Nice numbers - I saw similar gains on my '17 Camaro with E85.
I don't see a need to spend more money on gas on my truck since it's a DD so I'm not going to convert, nice to see the gains are good though
  • 3 years later...
I took my 2018 Tahoe to CJ Tunes over a year ago.  Converted it to E85, along with a 6.2L intake manifold and throttle body, as well as AirRad intake tube and air filter.  The end result was amazing.  Never dyno'd it but I would guess maybe about 450/450 crank?  It HAULS BALLS, and has performed flawlessly for 15,000 miles.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
