I'm Back
FishAr
Haven't been here in a long long time (apparently since 2002), my username used to be ryr8828. I wasn't sure of my username or password so I re-registered. Found my old username by doing a member search. I like this new name better anyway.
I registered here originally when I bought my 2002 blue 4x4 Avalanche, which I replaced with a 2008 blue LTZ Z71 crew cab 4x4, which I replaced with a 2013 green crew cab LTZ 4x4, which I replaced with a black 2015 Colorado crew cab z71 back in February.
I traded the colorado yesterday for a new 2015 double cab 4x4 z71 silverado 1500 with 5.3 and 3.42 gears in rainforest green. The colorado experiment was a mistake. When you make mistakes in life you either live with them or rectify them, I decided to fix mine.
Got tired of ducking to get in and out of the colorado, a few times I forgot and hit my head.
Better gas mileage but not so much better that it makes a difference to me. When towing my travel trailer mileage went down to 9 mpg.
Also I bought a new travel trailer that's bigger than my former one and at 5500 pounds I thought the colorado was at it's limit. It pulled it ok but I wanted more power and more safety factor.
Also my 100 pound yellow lab was kind of cramped in the back seat when we go on camping trips. If hauling my golf clubs and push cart to the golf course was all I was doing I probably would have kept the colorado even though I learned to hate the black paint.
I'll be 59 in a few months, am a gun enthusiast, a golf enthusiast, and like to go camping.
I retired 3 years ago from my trade as a pipe insulator but I still take on seasonal work. The union calls me when they don't have enough active members to man the work and I'll go out on the job for a few months to make some extra money. I've been working at the Wood River, IL refinery since October and still have a few weeks left there before I go back to taking it easy again.
I just realized I've typed a novel, so I'll stop it here.
Welcome back Mike, sorry the Colorado didn't work out, but you sure fixed the problem quickly.
My anticipated layoff date is December 11, I'm looking forward to it so I can bring my travel trailer home and pull it in with my new silverado.
I have it parked at a mobile home court not far from the refinery and have been living in it while I'm working up there.
I'm looking forward to taking pics of it and my new truck together when I get back up there tomorrow afternoon so I can post them here.
I knew I was going to take a hit but the dealer was very good to me. I was very happy with the trade and am very happy to be back in a silverado.
Now I'm on to using the search function for pics and reviews of caps and running boards. I think I've decided on an ARE Z cap, I had an ARE on my colorado and it was ok.
Also going to add a bed rug, had one in the colorado and loved it.
And possibly replace the mirrors with towing mirrors so I don't have to keep clamping on the removable ones.
I think I'll make myself a breakfast White Russian and start reading the site's content.
Great site.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
