local shop who installs Zone lifts told me that my stock 20" wheels will not work???? I've seen a ton of guys running stock wills with this kit, I wonder why they are saying that?
Because they are misinformed.
I have a 6.5" Zone and I am running stock 20" wheels just fine with no spacers required.  Tell them to install the lift and put your wheels on.  Then look at them and say, "You're welcome."
Edited by lapoolboy
It depends on what control arms you have
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
On 1/22/2017 at 8:26 PM, jimmyboy8301 said:
Zone 4.5" with 3" rear block instead of 4".
Please excuse the ugly wheels, it's my winter setup.
What are your fender measurements? I’ve got a 2.5” with 1.5” BL and wanting to go a little higher but the BL is screwing me if I put a 4.5” lift on, I’ll have 6” of lift on 33s..I’m not wanting to go bigger on tires just want a little more wheel well cap and maybe spacers for a better stance but with a lift the knuckle would push it out for the look im after..
It would definitely be nice to see some more tire lift combos with the 4.5” lift. Can’t decide what i want to do tire wise between a 33”, 35”, or getting a 285/65r20
i'm 42.5F / 41.5R , however i'm installing bilstein 5100s this week and setting them at 1.25" and also swapping out the 3" block for a 4" block so that should bring everything up about an inch
thanks man I appreciate it, I just wish I didn’t do the body lift because I think it would be too much with a 4.5” lift..I almost pulled the trigger on the 3.5” RC leveling kit with UCAs but too many bad reviews..I just can’t bring myself to do it..I’ve installed several lifts myself on my duramaxes and didn’t want to lift this one but I’m wanting as much height as I can run on 33s without it looking goofy..
If you go 10-12 wides 33s on a 6” would be fine
4.5" Zone
4.5" Zone
Yea I’m running 20x10s with 305/55 Mastercraft MXT..I’d think with a lift that pushes the front track width out and spacers on the back making the stance wider it might look pretty good..
It definitely will
4.5" Zone
Maybe to try and upsale you on a set of aftermarket wheels??
On 2/11/2018 at 5:06 PM, Rjax said:
Well here it is...finally got the Zone 4.5" installed about 2 weeks ago.
Truck looks good!
I sit somewhere in the middle of both kits. Zone 4.5” with bilsteins 5100s set at 1.25”
4.5" Zone w/ Bilstein and Fox
On 12/3/2015 at 4:05 PM, XMR15 said:
I vote 4.5 inch.
I have the 4.5 in my truck and love it. Lots high. I am running 35x12.5x20s with no rubbing or trimming.
Here is a few pics to give you an idea.
Nice looking truck.  I know this is an old thread, wondering what kind of MPG you get now after the lift & bigger tires?  You have the 5.3L I assume...?
Thanks,
Scot
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
