Help a fellow out?
Jlm02a3094
Ok, so on Friday I'm switching trucks. I got an amazing offer that I can't pass up. Currently I have a 2015 Sierra 1500 DC SLE All Terrain with the 5.3. I'm picking up a 2015 Sierra 1500 CC SLT Max Trailering with the 6.2.
On to the dilemma now.
On my "old" truck, I leveled it with Fox Coilovers which netted me exactly 2" up front and nothing in the rear. I then went with Fuel Assault 20x9 wheels with +1 offset and 275/60/20 BFG KO2's. Due to the aggressive offset, I was extremely close to rubbing with this size tire.
On the "new" truck I plan on getting the same Fox Coilovers. The part that I'm undecided on is the wheel/tire combo. I'd like to put something a bit wider on there but don't want any rubbing. I'd also like to avoid any trimming.
With that being said, I'm trying to see if anyone has any info on either of these 2 setups on a 2" level:
20x9 wheels with a +20 offset and 305/55/20 KO2's
18x9 wheels with a +20 offset and 305/65/18 KO2's
Basically I'm willing to go with a less aggressive offset to get the bigger tire under there. Any help is appreciated.
Josh
Which FOX coil overs do you have and do you have steel or aluminum control arms? Reason I'm asking is I ordered the FOX 2.0's for the aluminum arm trucks (which mine is) and they gave me exactly 1/2" lift before they even settled. I shipped them back to FOX yesterday after they finally agreed to pay the shipping. They, of course, were baffled as to why they only gave me 1/2" of lift on my 2015 4x4 All Terrain truck.
Why don't you just put the old strut/springs in and put the FOX stuff on your new truck? The swap takes an hour max. Or tell the dealer you want them to swap them out from the new truck to the old if you don't have your old parts anymore. Save yourself $1k in buying new FOX parts.
My "old" one has steel control arms. I don't know what the "new" one has yet.
The Fox Coilovers I have are 983-02-086
I can't switch them to the "new" truck because part of the deal I got was to turn in the "old" truck exactly as it is.
Josh
Congrats on the new rig, you'll love the 6.2L NHT. What are you using the truck for primarily? Towing, OR, DD, street rod, other?
FWIW, since mine was intended for towing a boat fairly regularly, its first job is truly as a tow weapon. Second as a winter sports battle axe for winter skiing. Family and sports hauling with moderate OR, but a ton of pavement pounding as well.
At the end of the day, while bigger/wider rubber was a preference, for us staying OEM height and rake with more aggressive rubber in stock size was a better bet for our purposes. I'll eventually do Icon or Fox at OEM height for the quality of suspension.
YMMV.
Thanks, I use mine for pretty much everything but towing honestly. I haul around quite a bit of respiratory equipment (O2 tanks, concentrators, ventilators etc). It's also my DD :)
So, no input yet on the tire sizing? I'm sure there's someone out there that has played around with fitment on the RC 2" right? The Fox coilovers net the same increase in height.
Josh
Not the exact set up you're looking for, but it might help...
I'm running 305/55/20 Nitto terra grappler g2's with 20x9 +18 offset wheels with the readylift 2.25" leveling kit.
Like others on this forum running a similar set up, I had slight rubbing with the front tires on the back of the wheel well carpet while cranking the steering wheel in reverse (more so if i was on an incline). I fixed the issue (from what I can tell) by doing what others have done with zip tying the carpet back. This provides another inch or so of room (only a guess).
You might want to compare the specs. on the G2's vs the KO2's since are probably not the exact same width & height.
Hope that helps some.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
