Subtle exhaust for 15 6.2 crew cab
emeryz28
Wondering what catbacks other members have and enjoy. This truck is far too quiet for having a 6.2 v8. With that said, this is my daily driver and I enjoy the quality of the driving experience the LTZ Silverado provides. I have no cats and straight through magnaflow style muffler on my Camaro SS and while it sounds amazing, I am looking for nothing like that. I just want something that has a better rumble idling, sounds good when you open her up but does not come with annoying drone or loud interior resonance when cruising.
I have had three 2014s and tried every muffler combo there is including muffler delete with and without flapper and resonator, Maggie 14 inch, few different Flowmasters. I have finally settled on a Flowmaster Deltaflow 50 series. Cold start and under throttle sound moderately aggressive but not to the point of pissing your neighbors off. Sounds great while cruising with no drone at all. It was even fine when in V4 before I tuned it out. Now I know sound is a subjective thing but this is what I have found out. Corsa sound like a boat exhaust to me as well as being expensive. Borla sound great but then again mucho $$$. The smaller Maggies sound AWESOME but V4 chopper and drone is horrible. Now there are times in town I wish I had a little more sound from the 50 but overall I like it the best. I see from your other rides when you need to be heard you can. I have tried to make a video but it just doesn't do it justice on my iPhone. Good luck.
Emery I would save the $$$$$ and simply have a competent muffler shop cut out the OE muffler and flapper valve and replace with a Magnaflow 12909. With proper measuring and cutting no extra 3.5 inch tubing is needed. Great deep sound at startup and when you get on it. You won't be disappointed with it.
I have the same thing. 3.5" in and out, 22" case length and no flapper or resonator. No drone in cab with tailpipe run out underneath rear bumper.
Here you go. This is my 6.2 with the OEM Flapper in place on a Flowmaster 50:
If you really want a cheap option, just chop out the stock muffler and replace with piping (take out resonator and flapper also).
Or, like me, I will probably just chop out the stock muffler and replace it with a 14" maggie or borla ZR-1 muffler (take out resonator and flapper also). If you are that worried about the chopper sound, get a tune eventually and disregard the AFM.
Watch my videos.. I saved a tin of cash and sounds by far the best sounding exhaust on a 6.2 on youtube.. it really sounds amazing and it's very quiet at cruise
On my 5.3L truck, I went with a Borla/GM Touring Exhaust and mated it with an Airaid MIT. There is no noticeable V4 drone.
I'm 95% happy with the sound quality (throaty rumble) and sound level (loudness), as I would like it to be a pinch louder. I'm sure that the same setup with the larger 6.2L engine would be perfect.
My MBRP sounds close to Silver Ice's setup with less rasp and its a cheap exhaust too. It's nice as it maintains the 3.5" single as I had no desire for dual pipes and trying to reuse the stock tailpipe is useless with it having the resonator..... plus lots of the these 6.2 trucks come with a 3" tailpipe and not 3.5" for whatever reason. I have no drone worth mentioning and about the only time you will ever hear anything is low speed in town if you let if shift from 4 to 8 constantly. So I just leave the trans in M7 for now and avoid that.
Figured I'd post my CORSA "boat sounding" system up on my new '15 6.2,no drone,and quiet when I need it to be,but aggressive when I want!....
BTW emery....I also have a 2011 Camaro SS LS3/6M....I did Kook's long tube headers and hi-flow cats along with a CORSA system on it as well,Its "a little" loud for sure,so I know what you mean when you say you want something a little tamer for your truck!
CORSA.MOV
CORSA.MOV
CORSA.MOV
CORSA.MOV
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
