How-To: DIY Oil Change K2 Pickups (Video).
fondupot
In order to keep oil off of your frame you could get a piece of aluminum foil and wrap it around the frame where the oil hits and then there would be no clean up.
Good video!
We use Fumoto (or similar) product on our trucks at work, but the drain plug on them is on the side of the pan. I would be constantly worried about road debris breaking that brass drain valve and dumping all of oil in the middle of the road. The next problem is hoping you catch it in time before you smoke your engine. Nice idea, but I will stick with the OE drain plug. As suggested previously, I always punch a hole in the filter and let it drain for a while. Also wear blue latex gloves when changing oil. Just pull them off when done and pitch 'em in the garbage. Makes the job a lot cleaner.
Good video...
Whats the general opinion on the best oil for these trucks? I've always been a Mobile1 guy but open to all if they are better
Its pretty much personal opinion. I've grown accustomed to Amsoil. So that's what I use. Mobile 1 is also good, Quaker State too. As long as you are keeping up with your oil changes, it really is just personal brand preference. I don't want to make this thread about "whats the best oil" because there are so many out there on the internet. But by all means do some research on Bob is the oil guy. See the independent testing. Then decide! :thumbs:
Good info. Thanks! One thing I was worried about with a fumuto is someone being able to just crawl under the truck and just open the plug and drain all the oil! Then if I dont happen to look underneat, I go to start the truck and seize it! Scary. But fumuto does sell a couple types of retainer clips that secure the valve in place that will require tools to remove before you can open the valve.
Good video!
Ah! Nice tip. I was thinking I should have put a rag or something down but I like that better.
Great video. Thanks!
Thank you!
Thank you!
Anyone could do that now if they really wanted. Once socket and a minute I could drain all your oil and unless you look underneath youd sieze it.
On the side of the pan as well and behind and very close to frame. Anything that would break that off is going to do damage to the pan too.
True, anyone walking around with a socket could sabotage someones oil plug.
And I'm not worried about the fumoto valve extending from the pan. Like you said it is behind the frame and is not any lower than the pan, so it should be ok. One thing I would be worried about is the spacing next to the oil filter. It could make things a little tight. Wont know til I throw one on there though.
I was thinking about this too much and was like actually id just drill a hole in your pan real quick haha.
Good point on the filter, like you said thatll be a try and see thing. Going to try it on my dads f150 as well.
ha, what a scumbag that would be to do that to someones ride.
Probably get low oil pressure and low oil level warning before it siezed.
Probably yea.
  • 1 year later...
I know it's an old post, but Great video! Just got a 2015 a couple months ago and need to do an oil change soon. Much rather do it myself.
  • 2 months later...
    tararebecca
    tararebecca
  • Who's Online   0 Members, 0 Anonymous, 522 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
