Configuring a 6inch BDS lift --- Recommendations?
BAD_GMC
If u like the way ur truck is now, ur gonna love it that much more LIFTED!
I still think I should go with the 4" because my tires are new........
that is what I have to keep telling myself.......
or...if I buy the 4" can I just buy the blocks and spindles from the 6" and be good?
  • Replies 30
After reading countless threads on various forums, people who are waivering like yourself tend to regret not going bigger. Unless you have crazy deal worked already I'd give it some thought to figure out what you really. For me on my 2012 Denali I went with a 4" and 33's because I had read horror stories of people blowing up the AWD system. Once it was all said and done I absolutely loved the outcome and never looked back. On my 2014 Silverado I went with a 6" and absolutely love it like my other truck. If you want the 6" BDS let me know and I can send you a copy of my invoice. I paid $2600ish for mine, shipped to my door. Thats with the Fox coilovers too.
Sent from my SM-G900P using Tapatalk
If ur still undecided, Go with the 6". I like how mine looks but I want it taller now. I hate it when HD trucks with just a level & 35s park next to me & we sit almost identical.
I think that is what is going to happen.
Sent from my Note 4 on Tapashit
6in is the way to go. You will have not to trim anything on your truck and you will be able to run 35's with zero issues.
I'm running a 6in RCX on my 2015 and its awesome. It rides great and the truck has a good stance.
  • 10 months later...
WOW, how did you manage to get the coilover kit at that price!!!!!???? I'm looking at doing the same to my truck in a week, but cant find anything below $3200. how do you like the kit as well? any issues with ride or performance? did you go with springs or blocks in the back?
Go to your local BDS dealer and you won't have to pay shipping. They should also give you atleast 15% off. You might get a better deal if you go this weekend cause of black friday. You can search for local dealers on BDS website.
Sent from my SM-G935T using Tapatalk
thanks i'll give it a shot!
Another member on here sent me a copy of thier invoice. Then the BDS dealer I used sent that invoice to BDS and they approved it. Then shipped the kit to me. Shoot me a PM.
Sent from my SM-G930V using Tapatalk
I just installed the 4.5" Zone on my 2017 with stamped steel control arms. the stock 20's with those arms caused the UCA's to rub on the inside of the tire once turned past 50%. I had the same setup on my 2013 with no issues, however due to the design of the stamped steel you apparently can't run stock wheels with them.
That is odd...I haven't noticed it on my '16 with stamped steel arms and factory 20's. I'll have to check tonight.
im running 305/55/20s FWIW
  • 3 weeks later...
I recently had a 6" BDS kit installed. I upgraded the rear shocks to the Fox 2.0's & the ride was great! My only dislike was that my front sat 1/2" higher than the rear. After 1500 miles I decided to install BDS add-a-leafs which added 1.5" to the rear which gave me about an inch of rake, exactly what I wanted. As for the ride with the add a leafs, I forget they're even there! Still an awesome ride!
Great experience with this setup. Hope this info helps you out with ur decision.
Keep in mind that the upgradable leaf springs they sell with the kit and Add-a-leafs are completely different items, but do pretty much the same thing.
My 4" BDS with 4" rear blocks has a small rake which i don't like. Not sure if the shop installed them wrong?? But it is a shop that is certified by BDS so idk.
The BDS 4" and Zone 4.5" will leave about .5" rake. I used a 3" block instead
Where did you buy the 3" block from? Can you share some pics of your truck.
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 684 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
