Leveled 15' 2500HD , what size tire can I go to?
What y'all mean "rake
Raked is an old racing term we used in the 60's. It's when the back is up high and the nose is lower, kinda like a funny car.
Meanwhile the opposite is "jacked". Jacked means the nose is up higher than the tail. Ofcourse jacked today means "using steroids". Lol
Funny how words changed over the years.
Jacked up
Raked out
Sent from my iPhone
  • Replies 126
Mine is leveled with a 35 12.50 toyo mt
What Kind of steps are those?
They are factory black steps
Sent from my SM-G920V using Tapatalk
Thanks. That is what I thought but wasn't sure. Going to have to get some.
  • 7 months later...
Hey jbee, what was the setup in the picture above? Tires, lift? Any issues with clearance or rubbing? Also how was the ride quality? thanks in advance for all the questions.
So with the 18x9 stock steelies work truck rims, I should be able to run 35x12.5 with no rubbing or trimming, as long as I have 2 inch leveling kit on the front?
If you have 18" stock steelies, then they're only 8" wide, with a +44 offset. A 35x12.50x18 is going to be close. I only know one guy who's done it on stock rims, and he ran BFG's...which are known to run small. Something like a Nitto Trail Grappler (which are known to run true to size) might rub the UCA. That being said, you should be able to run 295/70/18 or 285/75/18 without any trouble.
Leveled by turning up factory keys, air bags in the rear, 35 12.5 18 BFG's no rubbing
Sent from my STH100-1 using Tapatalk
Thanks for chiming in! :seeya: You're the "one guy" I was referring to, haha! I'm really curious to know if a 35x12.50x18 in any other brand would clear on your setup. Also, (and a bit off topic) did you do anything else besides cranking the stock keys?
I need to stop looking at this thread. I brought my truck home a couple weeks ago with the Transforce HT 245/75R17's on it, promised myself I would stick with factory-sized tires for fuel economy reasons, and swapped them out for 265/70R17 XTX Sport All-Terrains.
I cannot look at your truck without thinking about how big my next set of tires are going to be.
Thanks! Forums are evil places, lol
No worries, chiming in is what forums are for. Not sure if I'll be staying with the BFG'S for my next set. I'd like to get back into the "E" rated tire again.
As for what I've done to the truck, just turned up the factory keys, that's it, nothing else for up front. The air bags in the rear add about a 1" or so over stock when not loaded, and that's with around 5-10psi that I run them at when I'm not pulling my trailer.
"Well the prairie lights are burnin' bright, the chinook wind is a movin' in ..."
Sweet! Thanks for the reply. I'll quit hijacking the thread now, haha
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
