Midnight Edition Mods
Salmons34
Tinted front windows as legally dark as I could went 5% on back windows and rear with a 5% eyebrow on the windshield. Got running boards put on when I bought it. Changed taillights to anzoUSA led smoked, they are a little more gray than I wanted so I'm trying to find someone to take them apart and paint the gray areas inside the light black. Also removed the front air dam! Pretty soon I'm doing a "6 procomp lift with fuel 18"s and 35 ko2s. Gonna add a bakflip bed cover and some klearz turn signal lenses. I also want to change out the fog lights but haven't decided whether I want the putcos or if I want rigids. Oh and want to do a Corsa cat back but I don't want the tips showing!c890e5b8994f9bee652ef46aeb0647e8.jpga99a5bbc5180c6349748d7e3350bcbfd.jpg
looks good . led fog lights - check out what have you done on your K2 (this site) SAL9012 White Z71 - just put led lights on it .
  • Replies 158
Corsa sells a kit with black tips.
Ya I thought about going that route but the more and more I think about it I really want the exhaust to be dumped but I want to find out how it sounds and I haven't found any videos of the 5.3 with a Corsa catback that's dumped.
  • 4 weeks later...
I found my truck a few weeks back and I couldn't be happier.
So far, the only mods I have completed are tint and windshield film, Husky liners and a Tuffy console vault.
Next week I'll be adding leather, a Lund bull bar with LED light, and probably a set of running boards or nerf bars. I have been looking at the N-Fab wheel to wheel but I think I'll go with a 4" board / bar instead. I'm also debating between the Du-Ha and Husky underseat boxes.
I'll be reading through the LED thread for ideas but I'm debating between splicing into the fog lights and running the switch to the overhead panel.
photo's led / bull bar when installed . we have the same truck
i think i had the first one in ct i bought in may last year. 2 inch level with no air dam. i have a mbrp cat back so far, i really want to get 33's the stock tires look like pizza cutters. so hard to justify buying new tires tho when these are brand new!
Soft water, leaf blower, then final dry with a towel QUICKLY!
I put a coat of wax on my wheels as well, so that helps.
better question is how do you wash these dam things without getting waterspots!
lol... It's difficult that's for sure. Wash in the shade and use a waffle microfiber drying towel.
Lightly spray the vehicle while it's still damp with something like Chemical guys after wash spray.
Another tip - Make sure your waffle towel is also slightly damp. I usually drape it over the roof a few times before hitting the body of the vehicle.
has any one found a good set of led taillight for our truck - red /smoke ????? lets hear from you . thanks
Funny, I just read this after taking my truck through the wash this afternoon only to have it go through a thunderstorm.
I know it's a truck, but it's nice to have it all nice and clean.
I'm going to do a wax and seal on it in the next few days to cut down on the need to wash, though as a black truck it will need more care and feeding than others.
i know how you feel happens to me every time i can only see it perfectly clean one or two days. i dont go more than 2 washes without waxing it and i have the simonize glasscoat from the factory but it still sucks when u spend half a day cleaning it and on monday morning its yellow from pollen
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
