Basic Tow Mirror
I have an early build 2015 and would like to add towing mirrors. I ordered a set of aftermarket from ebay but sent them back as soon as they arrived. They were of poor quality. I don't need the power fold, lights or even directional lights, just power (upper) mirror and heated. I am not sure that even the base OEM towing mirrors come without the directionals. Any part numbers or the like from someone who has experience with this would be appreciated. I read somewhere that the early builds may need another harness or two harnesses per door but that might have been to go with the power fold option. Any help would be appreciated. Thanks.
All trucks need the door harnesses. Early build HD trucks (pre August 2014) and all 2014 1500 trucks need a third harness installed to make all of the lighting work.
Early build HD trucks and 2014 Max Trailer 1500 trucks had the old body mirror on them, with the new door mount plate. You could buy those (they just have the signal in them) and put those on. You will have power glass and heat, manual extend and manual fold. They retail for $502 each. You may be able to score a takeoff set or find them on a GM parts site that sells at discounts. The new style mirrors are sold in a kit and are $625.
Factory is still using the old trailer mirrors on work trucks.
Dealer should be able to use the chart/bulletin to determine exactly what you need if you want to add thru parts/accessories.
Here's the factory descriptions:
Available on WT:
DF2 Mirrors, outside high-visibility vertical trailering, Black with manual folding and extension and lower convex spotter glass
1 - Requires (Z82) Trailering equipment or (ZW9) pickup box delete. Not available with (PDD) Sierra convenience package.
Available on WT and SLE:
DPN Mirrors, outside heated power-adjustable vertical trailering, upper glass, manual-folding and extending, Black; includes integrated turn signal indicators consisting of 51 square inch flat mirror surface positioned over a 24.5 square inch convex mirror surface with a common head and lower convex spotter glass (convex glass is not heated and not power adjustable) and addition of auxiliary cargo lamp for backing up (helps to see trailer when backing up with a trailer) and amber auxiliary clearance lamp
WT - Requires (PDD) Sierra Convenience Package. Includes (DD8) auto-dimming inside rearview mirror.
SLE - Includes (DD8) auto-dimming inside rearview mirror. Included with (PDW) HD SLE Value Package.
Available on SLT:
DQS Mirrors, outside heated power-adjustable vertical trailering, memory-equipped, upper glass, power-folding and manual extending, chrome; includes integrated turn signal indicators, consisting of 51 square inch flat mirror surface positioned over a 24.5 square inch convex mirror surface with a common head and lower convex spotter glass (convex glass is not heated and not power adjustable) and addition of auxiliary cargo lamp for backing up (helps to see trailer when backing up with a trailer) and amber auxiliary clearance lamp
1 - Included with (PDR) 2500HD SLT Gas Premium Plus Package.
Available on WT:
Available on SLT:
The WT mirrors are manual everything. No power glass, no heat, etc. That is the only old style mirror they use.
