Small paint chipping
toms.abpg
I just bought and used a Dr. ColorChip kit. They are a little pricey (mine was around $60) but it seemed to work great!
I would love to know why my tailgate keeps chipping....... Honestly.... How does a truck that sees basically zero gravel and has not had a trailer on it in the time frame get a tailgate covered in chips. And no...... I have never, ever driven with the gate down. What...... rocks come off the tires and circle back defying physics and smack the gate? My truck just wants all it's paint to fall off.
I had the same issue as well so I ended up 3m the back of the truck a little.
Sent from my SM-N900V using Tapatalk
Mines beyond that now... and I honestly would have to have the tailgate covered in its entirety as I have chips from the top edge to just above the bumper. I will have it repainted when it gets bad enough... or swap with one at work going back to auction that's in good shape lol.
Sent from my SM-G900W8 using Tapatalk
  • 3 months later...
I have a 2016 Chevy Silverado paint chipping on front from small road debris this debris is undetected by sight or sound I have put approximately 1500 miles on this vehicle drove on the interstate maybe twenty miles on four different occasions no I do not follow behind semis I do not follow behind dump trucks there is no road construction every time I have drove the interstate I have looked at the front end and there would be more paint chips I have approximately 20 chips in the paint on the front of my Silverado and now paint is entirely too thin I have had other Silverados in the past 4 as a matter of fact and never had this issue the only time I ever had paint chip from the front of any of my Silverados you heard it or seen it when it hit GM needs to do something about this if I would have known I needed a clear protection over the paint I would have had insisted on this when I bought it
  • 1 month later...
How picky should I be about the paint job on my truck? I just got a 16 LTZ, that has couple paint defects. There are 2 spots that look like there's a tiny pebble under the paint. And there's one spot that has a little bubble on the passenger side door. Is this just something to be expected? I paid $50k for a truck, and that's the price of luxury vehicles. I wouldn't imagine BMW or Mercedes having this issue.
You can ask the dealer to look at it and try to correct it. I have 2 pieces of dirt in the paint on my 2016 along with a blemish on the rear painted bumper by one of the parking sensors where it looks like something smeared the paint while at the factory. When I go in for my first oil change I plan on asking the dealer to address the smear spot, the 2 pieces of dirt I am going to leave alone a as the repair would require a strip and repaint of the panel.
  • 1 month later...
Dodgersfan I would suggest not messing with it. I have been going round and round with the body shop and my truck and this last go around was for a spec of what appeared to be white paint in my hood, well a week later half of my hood has now been repainted. I did have about 10 "pimples" in my tailgate also but those were easily buffed out and did not require painting.
As far as chipping goes, I had some considerable chipping around my back window and third brake light. The brake light was due to the light contacting the cab and that was "fixed". As for the chipping around the back window I was able to convince the dealer that this was a material issue and not cause by road debris due to the fact that the area of the chips was not a road facing surface and would not have been caused by rocks or road material.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 607 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
