Leveled my truck
my gmc sales person measured a 16 slt z71 4x4 on the lot. front was 37.5" from ground to bottom of fender and rear was 40". that is stock so it should be what mine was before the level. i measured mine after the level and its at 38.5" in the back and 39.5 in the rear. so just 1 inch above stock.
  • Replies 50
Get a flashlight and look in there yourself! You will see the thin spacer under the bottom of the strut and you should see that round thicker one between the top of your coilover assembly and the mount on the truck. If they installed the full kit you should've gotten more lift than you did.
Went by 4 Wheel Parts at lunch and spoke to them. He went out and looked at my truck and said that both spacers were installed. He said they are both on top. That is different than what I was originally told (one bottom / one top). He said they were both on top and they did nothing to the rear.
Does anyone know definitively if both spacers are on top or if one is top and one is on the bottom?
The Asst Mngr I worked with originally is out today and will call me tomorrow.
NOTES:
2007-2013 Z71 Off Road trucks should use the upper spacers only.
2014-UP Z71 Off Road trucks should use the upper spacers only.
NOTES:
where are these notes from? who says it should be upper spacer only?
one guy at 4 wheel parts says both spacers are on top.
one guy at 4 wheel parts says one would be installed at top and one on bottom.
multiple readers and other sources online say one on top one on bottom on 2016 models
your notes says upper only. what source?
if it wasn't raining right now and i wasn't dressed in a tie at work i'd go under there and try to verify myself even though a guy at 4 wheel parts yesterday went under and said both were on top and nothing was on bottom
There is no difference between trucks. All Z71 gets you is the crappy Rancho shocks. Z71 or no, they use both spacers. There is no possible way for both spacers to go "on top". The round one is "on top" and the thin one with two holes (that line up perfectly with the two bolts on the bottom of your strut) go on the bottom. It is the most simple of things.
that is what is so frustrating about this. seems like it should be simple but multiple ppl thinking they are all the authority on it saying different things. i'll be speaking to the asst manager at 4 wheel parts later this morning to see what he says.
Did you look at your front suspension yet? I'm telling you it will be pretty obvious if bolth parts are there. They will look shiny and out of place.
It looks like all they did was the top spacer , if they have installed both on your truck would measures the same front and rear, I would go there and ask them to install both top and bottom. I have the pro comp in my 2014 all terrain!!!
Sent from my SM-N920P using Tapatalk
hope to look under there today. its raining outside right now. Just spoke to the asst mngr - he said he was sure both were installed. he is going talk to his tech and will call me back. he did remark that he thought mien was still a little nose down after the install.
hopefully i can take a look at lunch if the rain stops.
Here is what a 2015 z71 looks with 2.5" spacers up front only. I plan on adding 1" blocks in the back this summer, its a tad bit nose high for my likings.
after level
Looking at my paperwork now. It doesn't mention any parts installed in the rear. Just the leveling kit, labor and alignment. I'm calling when they open later this morning.
Any other pics out there of the 2.25 leveling kit installed?
Mine is leveled with the procomp 2.25 kit, same kit you purchased. There is a spacer on top and a spacer on the bottom. Truck sits just about spot on level.
Sent from my Note 4
Sent from my Note 4
Thanks, Any chance you can give me measurements where indicated? From the ground to the bottom of the fender flares front/rear and ground to body trim front/rear?
I would appreciate it.
I spoke with the 4 Wheel Parts Asst Mngr and he said the tech did install top and bottom spacers. Now they are saying that it will look more level after driving another 500 miles or so to give the rear shocks a chance to settle. He said that happens when they work on brand new vehicles with new miles.
While it may not be perfect I still think that the front fender flare should be more than 1 inch higher now than prior to level kit being installed.
Here ya go.
The 3/8 inch is completely unnoticeable when looking at it.
Sent from my Note 4
I found it in eBay someone describe this item.
2.25 Leveling Kit 07-16 Chevrolet Silverado/GMC Sierra 1500, 2WD & 4WD, 6-LUG
Maintain your OEM factory ride quality with BADLANDS leveling kit.
Easy to install No spring compression required
No cutting or drilling required
Does not require any permanent modifications to factory parts
Max lift 2.25"
Max tire diameter 33"
Minimum wheel diameter: 18
KIT INCLUDES:
(2) 6061-T6 CNC Machined aluminum strut extensions
(2) 6061-T6 CNC Machined aluminum lower strut mount spacers
Hardware: Included as needed
INSTALLATION: 1-2 hours. (Wheel alignment recommended after installation)
NOTES:
BADLANDS is a US manufacturer of suspension leveling and lifts kits we sell at the wholesale cost passing the savings directly to our customers.
This kit is a catalog interchange for Pro Comp 63235 and Ready Lift 66-3085.
https://www.ebay.com/ulk/itm/172104594859
