Do you like the adaptive cruise control?
52 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
No, the adaptive cruise isn't perfect, but I love it. This is the one thing I wished that I had gotten in our old custom ordered 2012 BMW X5d, but didn't. So the adaptive cruise was a must have this time around.
You have to play with the different distance settings I think. It brakes too late and tries to speed up way too aggressively when set to near. It seems to do much better on medium. When set to far, it's slowing down when a car is like a ridiculous distance away, so don't really use that much.
I used the adaptive today on I-64 coming back from Virginia Beach and heading towards Richmond. Between Williamsburg and Richmond, it's one of those two lane stretches of highway where you're constantly on and off the brakes due to a lot of on and off-ramps and only two lanes. This used to drive me insane without adaptive cruise. It really helps reduce driver fatigue with it. It's only looking at the car in front of you though. If the 5th car in front of you gets on their brakes, and then the 4th, and then the 3rd, you need to start getting on the brakes yourself because people tend to follow way too close. If you're waiting for the adaptive to do its thing and haven't gotten on your brakes by the time the car right in front of you is finally getting on their brakes, that's precisely how multi-car pile ups happen, which we did see on I-95 in Virginia today! LOL! Drove past a good 7-8 car pile-up precisely from this sort of situation. Also saw a crashed Tesla, that I think hit a freaking motorcyclist!
I let the adaptive do its thing, and it worked well, but it was definitely late on the braking once when set to medium, so switched it off. Again, it can only see what the car in front of you is doing, and not multiple vehicles ahead. It's a great tool to reduce driver fatigue. Gotta keep paying attention and maintain situational awareness at all times, though.
It is ok on our Yukon Denali (not offed on our Denali HD) and about mid range performance, but the Mercedes implementation on our E550 AMG Cabriolet works way smoother and does not shut off after coming to a complete stop. Also the HID headlights on the AMG turn with the steering wheel which helps out tremendously at night on a curvy road and wish GM offed that feature.
Edited by EXSlider400
I have ACC on both my Yukon XL and my Jeep Grand Cherokee, and I really like it on both.
For those so adamantly against it because it brakes too soon when you are looking to pass, you can override that by simply pressing the accelerator yourself.
It will not resume it's normal operation until you let off, so it can work much like regular cruise control with a tiny bit of driver input.
  • 1 month later...
I test drove the Lexus LS600 in 2008 which had adaptive cruise control it was nice... can sit in a lane and the car will slow down and speed up alone.  At that time if it stopped then needed to tap the gas peddle and it would get back to speed... not sure about the GM version
  • 2 months later...
  • 4 months later...
Does anyone have a 2020 Tahoe,  Yukon, xl, etc? They have a new “advanced adaptive cruise control” and I am curious what the difference between that and the regular 2015-2019 version.
Would be very surprised if they changed anything, given this is the last model year of this generation. However, I'd be interested to hear otherwise, as I have a 2019.
  • 3 months later...
In general I like the adaptive cruise control, however, on my 2020 Tahoe premier , if you get behind someone and say it’s set for 65 and you drop to 55 because they are running slow - when you go to pass it takes off like a bat out of hell to get the speed to the set speed.  Can this Increase in speed rate  be adjusted ?
    RyGuy43
    RyGuy43
  • Who's Online   6 Members, 0 Anonymous, 433 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
