Did they forget to reset the OLM when they changed the oil? Oil level and OLM have nothing to do with each other.
Very true. Devices like portable generators actually have a low oil shut down switch which will automatically cut off the engine if the oil level drops too low. this is to protect the engine which may run unattended for a long time. Normally cars and trucks ar e not equipped with such devices.
Am I reading that some people on this forum have to take their truck to the dealer to read the dipstick?
  • 2 years later...
I have a '15 silverado, 5.3L v8.  I've got a couple thousand miles to go before I'm due for another oil change (I go about 5K per change).  I got the low oil level alert.  OLM's at 60% FYI.  I have not seen any oil spots in my driveway so hopefully there's no leak.  The other times it's been changed, I've gone as far as where the OLM is at 30%.  Never seen this alert before so why now?  I checked the oil cap to ensure it's on properly.
Did you check the oil level with the dipstick?  Maybe look around the engine and underneath the truck for any sign of a leak?  You may want to install a catch can, as the oil may be going through the PCV system...
  • 7 months later...
On 2/29/2016 at 11:37 AM, Kerrslight said:
I used to check the level after an oil change but I've been going to the same place for years and never had a problem. I will probably check after work and see what it looks like.
I see how that could be confusing. My reasoning for saying the oil life is at 70% is just me saying I didn't have the oil changed that long ago. I know it has nothing to do with level, but I figured since it hasn't been too long it must've burned a lot of oil, has a leak, or just wasn't filled properly. I drive about 30K a year so I've been doing some driving lol.
All in all I was just curious if anyone else had a low oil level warning not long after an oil change. I will check when I get home and if I find its low, I should be able to have the shop top it off.
My gmc does the same exact thing I was reading the comments up and with the adding 8 quarts instead of 6 imma try that but I even took my truck to the dealership and they couldn’t find anything wrong I’m at a little over 80000 miles and a 2016 so if anyone else knows why please let me know. Thank you for everyone with their thoughts !
If you have a 5.3 or 6.2 2016 1500 pickup its takes 8 quarts not 6 to begin with.  Hopefully you haven't been underfilling your truck this whole time...
Edited by newdude
REALLY ! ?
No they’ve been putting 8 I checked the paper work  i thought they told me 6 but my dip stick isn’t reading anything and my truck computer is saying add oil when I literally just got the oil change like I said I took it to the dealership they did their test ****** and they can’t find anything wrong with it so if anyone knows anything let me know and my truck I barley drive it so it’s not like I’m driving miles and miles a day
Have they checked to see if the dipstick is in the correct position? Correct one for the truck?
What does your OLM say for a percentage after they change the oil?
Edited by JimCost2014
  • 4 years later...
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
