Diff covers
I hope you were being sarcastic TeeDub :crackup:. Josh, check out autoanything.com. The advantage to aftermarket covers are drain plugs and some heatsink fins to help dissipate heat.
the hard part will be finding one that fits the new rear end in these trucks.
guess i haven't looked in a while. g2axle.com now has one listed.
part number 40-2091MB
Hello Paint shop ??? now you got be thinking to add bull bar ,fender flar to a MidNite Edition ????? this sit could cost me money $$$$$
Definitely worth it. Without it your diff fluid will all leak out.
And the gears will get dirty too! :thumbs::crackup:
planning the trip to warren mi to get my 3.42's swapped to 4.10's and a new locker. will be bringing along the g2 cover for a swap while there.
A little off topic but what shop in warren? I have kind of been looking for a reputable shop to do a gear swap
drivetrainspecialists.com
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,410 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
