New GMC floor mats 2016 these are real nice!
Not a fan of how the drivers mat doesn't have coverage under the accelerator. That's where my foot is 90% of the time. If it was molded like the passenger side, I'd be a buyer. Those are great looking OEM mats though.
Your foot spends most of its time under the accelerator on the carpet? I suspect you don't go anywhere that way just saying LOL ;-)
  • Replies 182
Mine doesn't but, I hate knocking snow off my boots, I can see it getting on that spot in the carpet. IMO floor liners are there for convenience so I don't have to vacuum the carpets anymore, that spot being bare means I'd have to vacuum something. It's too bad if not for that they'd be great, It looks like the got it right on the passenger side.
It's a liability thing is my guess. GM doesn't want anything under the accelerator cause it could bunch up and possibly cause the pedal to get stuck. Toyota or someone recently got into a big lawsuit because of this.
The no floor mat under the gas pedal is a deal breaker for me. The mud and snow slop will end up under the mat in that area, these look great except for that.
Crap... My list of mods keeps getting longer, and more expensive. :sigh:
These look awesome!!
I feel the same way about the front. I want coverage under the gas pedal, and I like my Denali sill plate. I might consider buying the rear mats though.
Does anyone have a set of these where they've cut off the piece that covers the sill plate? I really like these but don't want to cover up my AT sill plates.
Sent from my SM-N910V using Tapatalk
Directions show how to cut out for sill plates.
Sorry, I worded that wrong. I should have said does anyone have a picture of a set where they've cut out the sill plate portion. How does it look when installed? (Meaning clean cut/factory look or like a hack job because the lines don't match up?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
