Well Hello There GM World....That Escalated Quickly
team250
Just like that, the driveway is full of GM/Chev. Had a 12 SRT Chally and a 13 Ram 2500. Can't complain about my ram trucks, all been good. The Chally was a pos.
Bought a 14 ZL1 Camaro last summer, its a beast in every form. Night and day over the Chally. I had a bad run of gm, my 06 and 09 turned me off and I went to ram. BUT....the company I work for just got bought out by an auto group that owns 9+ chev/gm/caddy dealers.
Soooooo.....haha!
Pick up my 2016 GMC All Terrain 1500 this weekend. Looking forward to making it mine. Nothing I have every owned stays stock for too long...lol. I will post some pics when I get it home. For now....some before pics....haha!
Soooooo.....haha!
http://images.tapatalk-cdn.com/16/03/21/2dfa77d8f3e79c74f4422c65d0f1de42.jpg[/img
Can't wait to get started on the 16!
Tires, tint, sled deck, visors, and decaling.
Sent from my SGH-I337M using Tapatalk
I have faith!
I do too. It's just sad though when someone switches to your favorite brand, or gives them a second try but they still end up disappointed.
haha, I hear ya! I was always a chev guy. I had a 90 gm that just wouldn't die. I went from that to a 03 Tundra which is still the best truck I have ever owned. end up needin a hd so in came the chevs again. they were BAD. I chalk it up to crap luck. my 10 and 13 rams were great trucks. both have never been in the shop. but this new gm is pretty unreal...even though I only test drove it so far...hahaha. love it so far. I just cant wait to put some miles on her!!
The new ones are definitely nice trucks.
Looks like you have good taste going with the white. Sharp truck for sure!
You're like the only person that has said that about the white! Haha, thanks. Everyone was telling me to go black. I may can't handle black. After my Camaro, never again. Although I did say that after my tundra, lol.
I've had two white trucks, wouldn't think twice about buying another.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
