2 Mods killed my mpg?
Hello everyone,
So I just installed a muffler and repositioned my flapper to be in front of the muffler. Since then as a result I don't get any drone one thing I've noticed is that the mpg went down by 5. I haven't been revving it, in fact I've been more light on the throttle than usual just to see if I could get those numbers back up. The only other mod that I did at the same time was switching out my DeeZee sidesteps with the AMP Research Powersteps.
Here are my best guesses maybe someone with technical knowledge can help?
1) Flapper relocation is causing MORE back pressure by having it prior to the muffler which is causing dampening in the engine making it work harder
2) The DeeZee side steps might have actually been helping with airflow around the truck since I'm keeping the air dam, by switching to low profile AMP Powersteps It creates more air turbulence around the truck.
I didn't expect to gain mpg or anything but I also didn't expect to lose mpg. It should have at least stayed the same.
  • Replies 48
Why did you have flapper installed ahead of muffler? Have to believe GM engineers positioned the valve after the muffler for a reason. I'd have to say you've created a restriction that has hurt efficiency.
The only reason I repositioned it there was another member had relocated it which got rid of the drone.
I don't think the step is contributing to a loss in mpg. If anything, I think it might help, less drag.
Have you hand calculated your mpg or are you judging by the tiny screen?
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
https://m.youtube.com/user/jorgerangel159
Im judging the loss off the tiny screen. I was getting 20 before and now I'm avg 15 on the same drive
The screen is always off on my truck. I always hand calculate it for that reason, but I don't think what you did could have a great impact, my guess is wind resistance and bad reading of the computer screen
DROPKICK Edition
DROPKICK Edition
What do you mean by wind resistance? I haven't changed anything that should effect that though except the sidesteps which should have helped right ?
That when you were getting 20mpg there wasn't any wind resistance and when you were getting 15 there was and your truck had to work harder to get your desire speed. Or your new exhaust system made your feet happy and you put the peddle to the metal but don't realize it cus it sounds to good lol. Have you reseted your average mpg screen?
DROPKICK Edition
DROPKICK Edition
I did the reset on the avg mpg screen and its low still. I still don't know what you mean by wind resistance. Are you saying that the weather was effecting it? I haven't been laying on the gas though for sure.
Did the other member have MPG issues after the flapper relocation? Flapper valve opens by pressure in the exhaust correct? Relocating it so far down the exhaust might have cause some blockage and it not open anymore? Just a thought.
Yes weather affecting it. You can feel when the wind is pushing on the truck, makes it feel heavier, that's a big factor on your mpg.
DROPKICK Edition
I'd figure out how to check that valve while driving, to ensure its opening. If it is restricted from opening all the way, it would have an adverse effect.
No way in hell the steps would have that much effect one way or another. Steps of any type would probably not have a measurable effect in the mpg.
If the wind hasn't been unusual, I would discount that as well. As long as it's been the same as the earlier comparison and you're driving the same route.
Best and final way to really check, is fill up to full, when pump clicks. Reset trip miles. Drive your daily routine, fill up again next morning, now divide your trip miles by gallons you pumped and that will be your average mpg and compare it to the screen average mpg.
DROPKICK Edition
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
