2 Mods killed my mpg?
Open up your flapper valve and test for a few days to see if mpg changes. Will help narrow out the flapper as a culprit or not.
  • Replies 48
Best and final way to really check, is fill up to full, when pump clicks. Reset trip miles. Drive your daily routine, fill up again next morning, now divide your trip miles by gallons you pumped and that will be your average mpg and compare it to the screen average mpg.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
https://m.youtube.com/user/jorgerangel159
I think this is going to be what I do. Im also going to try to test this with the flapper open. I haven't gotten under it to take a loot but I also thought maybe they put it on backwards?
Was the flapper installed in the correct direction?
Yes I double checked that :/
It might just take awhile to bounce back. Im going to do the gas fill test
Why did you have flapper installed ahead of muffler? Have to believe GM engineers positioned the valve after the muffler for a reason. I'd have to say you've created a restriction that has hurt efficiency.
Because most likely he did what I did and replaced the muffler with a single in/dual out muffler so instead of buying a 2nd flapper valve for both tail pipes he just had it put in front of the muffler.
mine is a single in single out but are you getting chopper and drone with your set up?
I believe the ones that moved the flapper valve were the ones that put in a dual out muffler so really you had no need to move the flapper valve then if you have a single in/single out muffler. And yes I do have the V4 drone because I don't have the flapper valve at all anymore. I'd rather just deactivate AFM if I wanted to get rid of it, but it doesn't bother me.
Did you have drone when you had the flapper valve moved?
If you read what I said, I didn't move it, I don't have the valve at all. I'm saying the reason someone would move the valve to before the muffler is if you replaced it with a single in/dual out muffler. So you had no reason to move the valve since you have a single in/single out muffler which is how the stock muffler is.
This made it seem like "I did what you did" and put it in front of the muffler....
I moved the valve because another member here did the same and claimed to have no drone after it.
What is "drone"? I would return to stock and see if that improves your mpg. I would also be careful about doing something simply because of one other member's success. You will often see in this forum where two members have apparently done the same modification and had different results. You don't know all of the variables that went into one individuals results.
Drone would be hearing the hum of exhaust while driving. I also have a pretty heavy chopper sound now that I changed out to a 3" pipe. Might do the range disable now to get rid of the chopper. I'm going to give it a couple weeks and see if the mpg comes back up. It could have just dropped drastically from speeding around and testing it. Easier to plummet with mpg readings than it is to rise lol
I am guessing that you have the 4.3 V6. After owning a truck with a 5.3 V8, I certainly notice the difference in sound!
No I have the 5.3 and that's what I was sayin I DO notice the change in sound which sucks. I'm considering installing a J pipe to mimic the Borla
I personally like the subtle rumble sound of the stock 5.3 when standing outside next to the truck. My 4.3 annoys me when idling with windows open but sounds fine while driving!
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
