Backup Camera help in 2016 2500HD
Purchased new 2016 last Friday of the lot. Negotiated a back up camera in the deal to be installed this week. They just called saying that cannot be added and wanted to return the cost of the camera. i would not have purchased this vehicle at this point in time without a backup camera option as I hookup to trailers single handed a lot. Why can't a camera be hooked up to the current screen?
  • Replies 34
Just go aftermarket, its not hard to install.
But it's strange that a 2016 vehicle doesn't h ave a backup camera Standard. I thought the Feds passed a law a bit ago that requried all 2016+ vehicles to have backup camera a standard.
If you really want, you should be able to force them to take the truck back. Just depends on how hard you want to fight with them. Good luck!
Got any specs on your truck? Trim level specifically. What radio does it have?
Based on another thread he started, looks like WT trim.
Its a WT. The radio is the 7" one with on star . I did the build a truck and didn't see any other options. They did come back and say another $100.00 for a different Radio with backup camera. I had to remind the sales manager that he sweetened the deal by throwing in the backup camera and I had fulfilled my obligation to him by purchasing the truck based on options, pricing Etc. So the new radio with backup camera is ordered.
Factory wheel wells installed( shorter than expected)
Running boards installed
Floor mats installed. The floormats are carpeted and have a hole in them to attach to the floor. Problem is the floor is smooth vinyl. Is there any way to get the male part and install under the vinyl? Options?
Seems like a lot of truck without all the options. I have a short wish list of:
New tires- largest 17 tire that the truck will hold?
Thinking of plastic dipping rims black.
Seat covers as the factory ones seem sticky or do not slide easy. They have a zipper in the back. Are there direct replacements?
Crank the front end as the dealer would not .
Any thoughts or opinions appreciated
- There are companies that make a rear view camera, one of them being Rostra. Problem is I don't think anyone supports the 7" new radio yet. Also, GM does not have a factory camera accessory.
- The HD sets are cut shorter for 5th wheel installation purposes.
- Take those out...NOW. The dealer should not have even sold those to you with a vinyl floor. GM had to recall all the 2014 trucks with vinyl floors because they were sending them with floor mats. GM bought back every single set. So...my advice? You have a giant floor mat already installed in your truck, I suggest you leave it that way...
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 2014 model year Chevrolet Silverado and GMC Sierra model vehicles when equipped with All Weather Floor Mats (RPO VAV) used with Vinyl Floor (RPO BG9). Some 2014 Chevrolet Silverado LD and GMC Sierra LD pick-up trucks were ordered and sold with the All Weather Floor Mats option (VAV) with the vinyl flooring option (BG9). All vehicles built with the vinyl flooring option do not have retention features for floor mats on the driver’s side of the vehicle. If the driver’s floor mat were to move out of position, it could interfere with the accelerator pedal travel, which could increase the risk of a crash. All vehicles equipped with the All Weather floor mats and the vinyl flooring option, are equipped with a Brake Torque Mitigation software algorithm in the Engine Control Module (ECM) that will override the accelerator input allowing the vehicle to be safely slowed or stopped by pressing firmly and steadily on the brake pedal.
Shouldn't dealer have some knowledge of options and accessories? I dealt with sales manager and service manager.
...one would think...some dealers do and some don't. Depends on if the people they hire give a sh!t.
Ok gentlemen, the saga continues. Truck went back to the dealer to install a new stereo with backup camera as in contract. I was assuming OEM. Wrong They installed an aftermarket Pioneer AVH-200 BT. Backup camera works however I lost factory functions like the USB in the console and the vehicle personalization. The back up camera does not work in the rear view mode. Only when in reverse. How doI get the USB charger to work in the console?
they are wrong. my truck came with pickup box delete. It came with all necessary wiring for the camera. all i had to do was buy a camera and harness. Then the dealer activated it. OEM screen works as it should. I would not be happy with aftermarket if I were you.
Do you have any any part numbers or details that will help me with this dealer? Thanks for your reply
bought the camera and harness from www.camera-source.com
GM released an update to activate the rear view camera. you need to check that the plug is there tho. on the drivers side by the spare tire there should be a block of plugs. one is the camera plug, and right next to it is an identical jack where you store the cover for the plug when you remove the camera
  • 4 weeks later...
Old Chevy link stereo back in. I had them leave the camera in to fulfill their obligation. I was just tired of them telling me it couldn't be done. I have called oemsuperstore and was told yes it could be done. I have to send the hmi out and lose the use of the truck for 5 days. $100
Has anyone installed the wireless camera for IPad? This might be a better option for me as I use google map on the iPad for navigation. I have it velcrowed to the dash $169 What's your opinion
Not much done so far.
Dealership logo removed
Black bow ties
Added black toolbox
Switch hitch plastic dipped black of course
Exhaust and tailpipes and muffler stove pipe black.
Wish list
1-steering stabilizer
2-Under seat storage
3- crank the keys- what size socket needed ?
4 new tires
Anyone plastic dip their rims?
Two dealers will not activate camera. They claim liability will not allow them to activate. They also said getting reflashed aftermarket will void warranty . Chevy really does not want to be customer friendly.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
