Vinyl to match White Diamond Tricoat
I found some on amazon about 2 years ago that matched my white diamond impala. If I remember correctly is was like an 18 inch by 3ft sheet. I used it to cover my emblems and matched really well. I may still have some left over. I'll try to see if I can find it and see if it had the name of the company that sold it through amazon.
Came from a company called wrapco llc. Ikon wraps out of San Antonio TX. www.ikonwraps.com. 1 ft by 5 ft sheet for 14.99.
This is what I have ever left over.
avery makes it too...or use to. i had it on my 2003 CTS to color match the trunk bezle and the headlight eyelids.
it was very close, 2 layers over the darker colors like the bezle would have been much better.
i also did the yellow/abmber sidemarkers and covered the signals above the fogs.
i liked it.
i was cleaning out my garage last week and found a little of it but i dont think its enough to do the grill.
if you cant find it let me know and ill go out and measure, but honestly best bet is to have your grill painted if thats really what you want.
soak the chrome in scotch bright to remove it then sand, prime and have it painted.
Keep us (me) posted. Was thinking about doing it too. There was another brand on Amazon but they also had Avery.
  • 1 month later...
i liked it.
Mike? ahah finally found you on here.
haha Ya buddy!
i saw on FB you got a new trcuk? got sick of the all terrain?
i really like the look of the new silverados especially in the white.
when the time comes ill probably be going back to white paint, but crew cab standard box but i havent even hit 60k yet in my 14 lol
haha Ya buddy!
I was ahead on my loan, got 9k more than I owed. ended up in a new truck, with warranty, and more options for the same payment. basically hit the reset button on my loan.
and loving it!
I just ordered a sample of the Avery brand from eBay...we shall see
Did you get the sample and try it out? What were the results?
  • 4 weeks later...
and loving it!
Awesome.
im debating on trading mine in for a new one (almost did it back in feb) or just keeping it and getting a smaller car for my girl.
im just about to hit 60km on mine and i still love it...banged it up a little this winter, need a new rear bumper from backing into a snowbank on purpose just for a little extra parking room that happened to have a steel pole in it and my bike tipped into it and dinged a door but a paintless dint removal guy can fix that.
New to the forum here. Does anyone know of a certain vinyl that'll color match the Crimson red tintcoat (burgundy) for a 2016 GMC?
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
