1996 k1500 fuel pressure problem
96 k1500 5.7 vortec. So about 2 weeks ago I replaced the fuel filter and fuel pump. And the fuel pressure read 50psi with the key on engine off. So today I replaced the fuel pressure regulater and found out the truck has the new electronic fuel injection spider on it. After replacing the regulator I tested the fuel pressure and it jumped to 50psi and went down slowly to 20psi. I tested the pressure right before I changed the regulator and it was holding at 50psi. Also the truck runs good when you are on it but idles at at 550-600 but it idle kinda rough and sometimes will stall. Any help would be appreciated.
Any SEL or check engine light or codes?
  • 4 weeks later...
Good luck. Mine has no power and breaks up bad over 3500 rpm. New fuel pump,(3rd one) new fuel filter and fpr. No change. Started my issue a few days after last fuel pump. Im done. No codes. Nothing
Have you checked the condition underneath of your distributor cap? I know it sounds crazy but I had the same condition and it was my aftermarket distributor cap. The contacts had melted.
Man I had the same problem. I burned out 3 pumps in about two months before I found the bad ground. Would run fine great psi for about a week or 2 then it would get sluggish and not rev over 3500 rpm
