best bed extender for 5'8
Hey guys I traded in my 14 LTZ double cab with standard bed for a 16 HC Crew with short bed so it can fit in my garage... I am looking for a bed extender now can you guys recommend one and where you got it from? Thanks
Amp has good stuff. All 3 of my BE have been amp
By the way I thought the cc with short bed was same length as Double cab?
No the Double cab usually has a 6.5 bed also now known as the standard bed.... Short bed on the crew cabs is 5'8. Long bed is avil at 8ft
The double cab is 230 inches in length. So is the Cc with short bed. Either way amp is good products
O i see what you guys mean now... yes the truck length is the same but I wanted the crew cab but had to get a smaller bed now with the crew so i can fit in the garage.
I have the OEM GM extender, it was easy to install and is nice in that it locks into the gate latches to hold it down.
It is the same thing as the AMP HD Sport which has a semi triangular shape. I would prefer the standard AMP HD so all the tailgate is caged in.
How much drilling was needed on the OEM extender? I am interested in getting either one.
It was 4 holes in the truck for the mounting brackets and four in the extender to rivet the sections of the extender together so it can't fall apart.
Came with a template that you tape on and center punch, drill and bolt the brackets on.
Wish I would have drilled for install before I did Line-X so I could have skipped the priming of the holes I drilled in the truck. Ahh hindsight.
What about a folding bed extender rather than the typical gate design? I hate to admit it, but Ford has an ingenious design with one that folds up into both sides of the bed so that you can load the truck with the tailgate down with cargo (i.e. dirtbikes like myself) and then unfold it to wrap around whatever you've put in the bed. With these gate ones, it makes it impossible to load while the extender is connected. I'm sure Ford has a patent on it, but hoping someone out there knows of a design that fits the Silverado. Might have to just buy one of the ford ones and make it fit.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.   [img]https://live.staticflickr.com/65535/55462229387_5c9bbe5416_b.jpg[/img]   NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.   [img]https://live.staticflickr.com/65535/55463207451_16a229e2f8_b.jpg[/img]   I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:   [img]https://live.staticflickr.com/65535/55463598785_88e6de0164_b.jpg[/img]   And the issue which occurred because the front rail clamp was too far forward:   [img]https://live.staticflickr.com/65535/55463206526_7d19819403_b.jpg[/img]   Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.   [img]https://live.staticflickr.com/65535/55463377309_a18f23d493_b.jpg[/img]   The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
