Camaro Z/28 crashes at the Nurburgring
http://www.camaro6.com/forums/showthread.php?t=452143
the Consensus at the Camaro6 forums is that it might have been an ABS or Stabilitrak malfunction that caused the rear wheels to lock up when the test driver was braking for the corner, the driver tried to compensate, over corrected, and into the wall it went. this pretty much tells me that the Z/28 is going to be a car that demands high driver skills, or else you are going to be eating wall, whether it be made of Tires, Concrete, or Steel.
being my own hillbilly expert..
the wrap killed to much static ground, magnetic poliarity took a stab.
I see even where an aluminum diffuser would be on a ricer is wrapped in the video (between the tail pipes)
hardly an error. Call it constipated.
loosen it up.
The Chief Engineer (Al O.) over the Camaro was at IMS yesterday and spoke about the Z/28. He did say they had the car up and running the next day.
