7 hours ago, Mr. Carolina said:
Nice! Doesn't look too jacked up and sits high enough for me. I've been looking for one, thanks
Thanks, ya I have an older chebby with a 4 inch and the huge trucks aren’t my thing anymore, this is my ol beast, just use her for work and the nasty stuff lol
Edited by ross001
I’m tired lol
Just joined the club after finally finding the new headlights for a decent price. Had the harness from Vann for awhile. At one point I connected the new headlights and went to grab the bolt to secure it, and the headlight fell and the harness split apart at the connector. So I had to re-wire it, but it all worked out in the end, no issues!
That looks sweet! I got a deal on the passenger side and waiting for one the drivers. Where did you end up buying them?
Off eBay, I'm in Canada and got a nice set from Canada as well. Took months of waiting though.
Edited by roadblock
Looks good! I finished mine a couple weeks ago and forgot to post pics. I did a lot more than just heads and tails but I am pretty happy with how it turned out.
Changed from SLE to A/T Grille
Black GMC letters
Powdercoated front and back bumper
Added Morimoto XB LED Fogs
2017 Headlights and Taillights
Replaced Front Bumper Skid Plate (old one had a hole in it) and added the License Plate Cover
Edited by bwright2112
Black GMC letters
Nice work! Really cleans it up! I forgot to mention I had the Morimoto fogs in already from the group buy. I need to do something with that tow hook surround next. Anyone know if it's hard to get off? Maybe just plasti-dip it as is?
I couldn’t decide if I wanted to leave the plugs in or buy tow hooks but being a regular cab I decided to pass on the tow hooks.
I left mine as it was. Black plastic from the factory. I thought about painting it but I think it looks ok with the flat black on it.
It wasn’t hard to get off for me because I had the whole bumper off ha ha but it does all bolt/screw/clip in from the backside of the bumper.
Now that I am thinking about it though I’m not sure if you can get it off without the bumper being removed. Surely that isn’t the case though. I wasn’t paying a whole lot of attention as I had to remove the bumper anyways but I know I put it back on before I put the bumper back on too and I was looking around behind there and I don’t remember seeing a way to get to those screws. I wonder if you could get it off just by taking the plastic piece above the bumper off though. That would make a lot more sense.
I went on a 2800 mile road trip LA to Coer de Alene Idaho and back in 5 days, in my 2014 fitted with the 2016-17 LED headlights, to pick up a new bird dog. I did a bit of night driving with these LED factory lights.  I’m pleased with the side visibility. They seem even better than the 14 halogen projectors, with a TRS HID kit I had for 3 years, for side lighting.  The forward distance lighting isn’t quite as good as HID in the halogen projector. But it’s still good, and much better than the original all stock 2014-15 halogen projectors.
My opinion of the Rigid Industries SAE fog lights is mixed.  In heavy snowfall, the fogs made it harder to see.  The sharp cutoff of the headlights made the fog lights not only unnecessary, but obsolete.  The SAE fogs do add some side visibility when I don’t want to burn the paint off the back of a vehicle in front of me with my Baja Designs driving lights.
Edited by Spurshot
2015 Denali, I hated the halogen in projector lights and ordered the HID replacements that fit right in the projectors. less than 2 hours to install and less than $200 for the entire kit from RetroFit. So bright you would be amazed! Love them! I also got the super bright LED replacement fog lights that have the same flat on top beam look as the projectors, WOW, 200 % better than stock! They also were under $200 per set. I am now super happy with the light brightness and projection. My son-in-law was so impressed he installed same set up on his 2015 silverado
What kind of fog lights are those? Are they brighter than stock?
I think those are The Retrofit Source (TRS) fogs.  https://www.theretrofitsource.com/assemblies/led-fog-lights/gmc-morimoto-xb-led.html
Stock fogs are 500 lumens each. TRS fogs are 1200 lumens each.
    Smitty462
    Smitty462
  • Who's Online   4 Members, 0 Anonymous, 572 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
