6 hours ago, smatti said:
Prior to installing these, did you also do the BCM flash that provided more voltage to the headlights? I know the 14s experienced this issue and GMC released the following TSB # PIT5374B to address it. I'm trying to determine if the BCM update would be beneficial or if it's not needed with this new set of lights.
Thanks,
Matt
I recently had my truck in for service to do small 4-5 recall items. Not sure if the BCM flash was done. The new lights are strong enough that I don't notice my ProBox/Rigid fogs adding as much to the throw as before
I believe LED are voltage range tolerant and output isn't affected much by voltage variation.  But some of the electrical engineers we have may chime in with better info.
On 2/13/2018 at 8:01 AM, Spurshot said:
I noticed my left DRL ring has an intermittent flicker.  It does it only when the engine it running.  It doesn't flicker all the time.  But about half the time it flickers.    Any help would be appreciated.  Is this a capacitor issue or a headlight assembly issue? Wiring?  I have the short jumper harnesses from the OP.
http://www.ddmtuning.com/Products/BOW3
will remove dash errors on most vehicles with bulb self check systems. Will also fix flickering of DRL's when used in conjunction with one of our HID harnesses.
Denali? There were a couple Denalis/6.2L that had this issue. Havent seen any 5.3L with a flicker. If I remember correctly they flickered only when the turn signal was applied. Both were fixed using the drl mod. There is no capacitor on the DRL Its using factory functions. The cap is on the low beam only. Only one side?
Edited by zmnypit
Just finished my headlight and tail light upgrades. Truck looks great! Much thanks to zmnypit for the adapters and technical support.
  • 4 weeks later...
I have the 5.3L SLT. and my driver side DRL flickers every once and a while. What DRL mod fixes this?
Before I swapped headlight assemblies, I added the first version of the vled lmz led lights, had a very faint flicker on my passenger side lol. Couldn’t notice unless I was at a stop light and could see it reflecting on the vehicle in front of me. Never noticed it driving though. 2015 SLT.
Hard to say. I know it did on the denalis but I have yet to see any 5.3s that flicker. I've asked around as well as check with all the locals and not one has seen or noticed a flicker. Im scratching my head on the 5.3
Has anyone ran into the truck throwing a code to onstar after swapping assemblies? I’ve noticed in the monthly email diagnostic reports for a good year or more, that there are items needing immediate attention in bold red letters in the opening paragraph. But when you look at the systems, everything is shown as good.
Well I was in for an oil change and I asked the dealer a couple weeks back to look it up for me, they said it had L/R headlights shown as the problem, but couldn’t see anything other than that and referred me to onstar. I called onstar and opened a case. I told them my lights work fine, And the dealer checked them as well and everything was working fine to them.
Onstar got back to me and here’s the email below, any idea what these codes mean?
I have worked case number 84995610 for your 2015 GMC Sierra, and have resolved the issue.
The OnStar Vehicle Daignostics (OVD) emails was showing there was a diagnostic alert for your vehicle this month requiring immediate attention, but there was nothing listed below that needed attention.
The diagnostics did show alerts are for left front head lamp and right front head lamp for your vehicle and that's what triggered that warning at the top of the email. We don’t currently have a fix to include the bulb alert in the email display.
The problem codes are legit though for the bulbs and those codes are B2575 and B2699. I know you stated the dealership already looked into the issue and found nothing wrong, but the computer system in the vehicle is still reporting these codes. Please refer to the service department of your dealership with those codes to be addressed or cleared.
If you have additional questions or concerns, we can be reached at the number listed below, or you can reply to this email.
Thank you,
Kelly
OnStar Connected Vehicle Support
Phone Number: 1-888-4ONSTAR
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
