Painting exhaust tip question
So this holiday weekend I'm planning to paint my OEM exhaust tip to a satin black. I have a can of high temp ceramic paint ready to go along with a red scotch brite to scuff it up. Should I lay down a high temp primer to? Or is there another way to paint it without ruining anything? I thought about plasti dip but I just don't want that. Any help is appreciated!
From what I have done and seen the high temp paint is going to chip, You mentioned pasti-dip... there is a guy here in Clinton and that's exactly what he did on his 2500 HD and it's holding up pretty well.
RT
Why not just buy a black exhaust tip?
Because I like the look of the OEM tip
RT
I wanna give the exhaust tip a satin finish. Don't think I can pull that off with plastidip ( pun not intended )
Powdercoat.
- Mike
IG: @BlackPearl_Edition
I heard powder coating can't hold up to the heat and will become brittle
Robert is correct... I tried this a few years ago on my sisters corolla... I found you this video.. the black plastic dip will give you the satin look
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
