Just wondering if anyone had pre-leveling measurements?
My 2015 z71 double cab sits at 36.25" in front and 39.25". I planned on getting the rc 2.5 lift level, but it seems the front won't be level even before adding the rear spacer. Then I thought about a motofab 3" front, 1" in rear for a bit of rake, but heard 3" might be too much for the front ball joints.
Anyone have a large amount of factory rake (3+ inches)? What was your solution?
Thanks!
FWIW, my 2015 Z71 Regular cab measured 36.25" front and 40" rear on the drivers side. Not sure if you have the aluminum block in your rear suspension like I had, but removing that yields a 1 3/8" drop
Did you level it? Since you have almost the same rake I was curious as to your solution.
There is a lot of information and opinions on this forum regarding your question. I believe that if you level your truck so that the top of the front and rear wheel wells are equal distance to the ground your truck will look nose high.
Ding...ding...ding.. we have a winner. If the top of both wheel wells are level the truck will look nose high. You have to measure top of hood and top of bedrail then look at how much to lift the front.
Interesting. I know everyone uses the wheel well measurements. Guess I'll need to do some more investigation.
You are right that this is "interesting". It is a matter of personal preference and the positioning of your vehicle. Unless you can afford some "trial and error" installs then I recommend more investigation. My wife doesn't always share my "priorities" so I want to get it right the first time! I would go with a 2.5" level if I was adding a 2" block to the rear. (I believe stock block is 1.25"). I would only go this high if I was going to go to 33" tires. I was set (until yesterday) on a 1.5" level with and a slightly over stock tire size. My dealer currently has a truck in the showroom with a 2" bottom of strut spacer and upgraded stock size tires. To me, this is a perfect look! It looks great without my neighbours thinking I'm going through a late mid-life crises!
I'm probably the only person on here who likes the factory rake. It reminds me of my 91 Silverado as they raked them as well.
But as for changing ride height on other vehicles the tape measure only ever comes out once I find a profile I like.
By that I mean I take the tires off set them just off of the studs.
Then raise and lower the back and front until I like it then measure so I can order the parts to give me what I want.
I'm not sure why people buy stuff then decide they don't like it after the fact.
A set of adjustable jack stands and a couple of jacks is all it takes.
here to pic whore.
2.5" rc level. nothing touched out back (lulz)
looks good to me
That does look good. What size ko2, and do you like them? They're on my short list to put on my 18" wheels.
Nope, you are not the only one. I personally do not like the levelled look as the top of the truck box is lower than the hood on this body style. Put a bit of weight in the back and it looks like a dog dragging it's *** on the ground.
If I were to do anything it would be a lift and level with a 2.25" in front and a 3" in back.
love em.
285/65/18
I like a bit of a rake as well for functionality and looks. I also like a bit of height in the front of a 4x4. A little lift (1.5 - 2") of the front end won't reduce your load carrying ability or necessarily cause your truck to squat. If you want to maximize the lift from a level kit (2.5" - 3") and maintain load carrying integrity then rear blocks will be a solution.
  • 5 years later...
Have done some research and wanted to follow up with a question regarding my truck (shown here)...after taking measurements (from ground to edge of wheel well) Im noticing a 3" difference from front & back (36" in front, 39" in the back) and when looking on RC website, it looks like the standard level is 2" -- they also have a 2.5" level kit as well but the price jumps $100
Why is the 2.5" kit so much more money and am I even looking at the right one? Any help from someone who has done this before is super appreciated!
https://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html?find=2018-chevy-silverado-1500-4wd-739610#278=516
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 680 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
