What is this for?
Red looks like a power cable, perhaps for an AMP?
yellow connector indicate wiring for airbag system
black connector is a junction connector to connect somes wires togneter
big red wire is aftermarket and it is to connect an amp for audio probably but this one you should know if you bought the truck when was brand new
