Need some help on wheels 2016 Denali
I would be interested in your stock rims if you decide to get rid of them. I have polished aluminum on mine but would like the chrome. 69532c92b3744d0814a57372dffc62d9.jpg
Wish I would have bought the color of your truck, looks great..but could only find the 6.2 in a black one.
If i ran the stock rubber on a new set of rims. What offset could I run and not have the tires sticking out the fender alot?
You'd wanna match or be close to factory offset...
If you want chrome, you want chrome. But I gotta say the polished aluminum looks killer. You have a beautiful truck man.
