Was able to replicate the sound with a tech that came for a ride with me. Offered to let him drive to see if he could hear it better from the driver's seat but he said its just the noisy high pressure fuel system. I'll learn to live with it unless a more common fix comes out. They didn't see interested in looking up any service bulletins, so there was no mention of PIP5395D
I did find the TSB online though. It's for cars but the last part is relevant
"Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment
Vehicle Technical Service Bulletins Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment
TICKING RATTLE OR BUZZ NOISE HEARD THE BEST IN THE PASSENGER COMPARTMENT
#PIP5395D: Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment - (Feb 8, 2018)
Subject: Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment imag
Supersession Statement
This PI was superseded to update Model Years. Please discard PIP5395B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
A customer concern of rattle or ticking noise that is louder inside the vehicle than outside.
The noise may be picked up at the back of the left valve cover.
The noise may also sound like a lifter tick.
This may also be called a fuel line buzz or ringing noise.
Recommendation/Instructions
Listen to the fuel line connection at the left side of the engine.
If the noise is heard best at the fuel line (this sound will be real loud with a stethoscope).
The fuel feed line between the high pressure fuel pump and chassis fuel line could be the cause allowing high pressure pulsation back to the low side of the fuel system. There is not a good way to test the check valve, the line will need to be replaced.
On pickups and SUVs, a vibration in the fuel line at the fuel tank may also be observed.
There are two different fuel line types that contain this check valve and vary by model."
I've been following this thread for a long time, hoping for a resolution.  My truck has had the tick almost since day one, but now has a buzzing to go with it at 12k miles.  I am scheduled to take it into the dealer next Monday and plan on showing them the TSB info.
If the dealer won't change the fuel line part, has anyone attempted doing it themselves?  The part itself is cheap.  Accessing the back end of it looks like a pain.  I've never worked on fuel systems before, so I'm not sure if it's plug and play, or if there are other steps like having to bleed/prime the fuel system after the part is replaced.
https://www.carid.com/2017-gmc-sierra-fuel-delivery-parts/acdelco-original-equipment-fuel-feed-line-188670616.html?parentsubmodel[]=ENGINE|5.3L
My dealer changed both fuel feed line, fuel feed pump, and full exhaust.  The sound won... I couldn't deal with a truck that made that noise constantly, while all the other loaner sierras I got were quiet as a church mouse.  Just got rid of the sierra and couldn't be happier.  Good luck to ya'll - i'll keep an eye on this thread to see if a fix is ever found.
what I'm not understanding about this service bulletin is if there isn't an updated part # on the fuel line, how would replacing it with the same one change anything?
Makes me want to call the dealership back, but looksstock mentioned that it didn't fix the problem
I have zero hope that the dealer will resolve anything, but I want to get my complaint on record.  Luckily I have the AC blasting all summer here in the south and it covers up the sound for the most part.  The sound seems more sporadic in the winter.
I think the problem is in that check valve.. what I also think is a problem is many of us are thinking this “ticking” are different things based on our own perception. Some may be talking about the distinctive noise of the direct injected motor, but the sound I’m talking about is very fluid like/air like. It’s gotta be exhaust or fuel related and it comes only from the footwell of the cab and will stop and start on a dime at random and can be triggered by bumps.
i can assure you that's exactly what I have. I was entirely convinced it was exhaust related until reading about this line. This is different than the typical direct injection sounds described in other posts
Injector tick I can deal with.  I am hearing a chugging (see this video from a different post, mine is the exact same).  Plus I now have a buzzing/air sound like an exhaust leak.
yes, that is EXACTLY it
My phone must not pick it up as well cause i have made a few videos but not as clear as this
Edited by jasinger
I think the fix is that check valve it makes the most sense to me. It’s a very distinct sound, I’m going to have my dealer perform the tsb sometime in the near future and see what happens.
Link doesn’t work for me
Here’s a video of mine, turn the volume up so you can hear
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
