I just noticed that my 2016 Sierra Denali with the 6.2 engine has a gas smell inside the cab. Not fuel but it smells like natural gas. Truck only has 4800 miles and I just noticed it this week. This happens when the truck reaches normal operating temperature. Ideas?
I'm not a mechanic by any stretch of the imagination, nor have I had my truck for very long, but I'd have to guess that it's something with it being new possibly burning off or heating up enough to generate an odor. If anything, contact your dealer if you haven't already, or if no one here can provide any better insight. Just my $0.02.
Thanks Chris - I will schedule a trip to dealer it's just I know these types of issues are hard to replicate and or diagnose. Hoping to find someone with same issues.
It could possibly be a leak in the exhaust system somewhere. Maybe someone failed to tighten some exhaust clamp or bolts.
Could very well be something with exhaust. It does have that funky smell due to the converters.
As stated by others, it is probably exhaust. Rotten egg smell from exhaust/catalytic converters is likely, it used to be more common than today.
The "natural gas" smell is added mercaptan to give natural gas a skunk or rotten egg smell.
is it only when you have the upper vents blowing air (AC not on)? Mine smells like hot motor oil but I don't have any oil level issues and it's only when the upper vents are on.
Yes! Only when AC is on. and they just changed my oil for the first time two weeks ago. It started around then. You think there is some residual oil burning off?
not sure. mine only does it when the AC is off but vent fan is on, blowing in hot outside air. I don't know what it is but it's been doing it for since new when it's hot out. I have 12000 miles on mine. Maybe whoever assembled the blower motor over-lubed it.
I believe blower motors have sealed bearings, I doubt someone just liberally pumped grease into them through some grease fittings and made a mess.
Edited by pm26
For those that care here is the update. The dealer said the differential fluid is overheating and thus creating the smell. It is because some bearing is causing some issue. This is the third truck they saw this happen to. I got a loaner. They said GM is aware of issue and TSB may be around the corner. I will post the entire ticket up here once they are done with it.
Edited by HyperX
could you smell it outside the truck or only through the HVAC system?
Outside as well - you have to pop open the hood and the smell is on the drivers side forward area. Very pronounced.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 828 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
