I've got a 2016 CC LTZ short box and no matter what trailer I pull i have no drivers side turn signal or brake light. I even rewired my trailer (and my buddy hooked up his truck to it and it works fine) and have pulled my buddies boat( didn't work on mine). Still doesn't work. I am bringing it in to the dealership on Monday. But just was wondering if anyone else has had the same issue?
Loose ground somewhere is 99% of all trailer light problems. I was once told by an old time to not rely on my auto lights and to turn the lights on manually. He said it will help "keep the ground clean" whatever in the heck that means. Hopefully dealer can figure it out.
Did you check the trailer light fuses in the fuse box under the hood?
This. My 15 Sierra popped both left and right signal + brake light fuses recently. There is 1 fuse for each side that does signal and braking. Running lights are on a separate fuse.
Edited by LowbanksArcher
But the truck lights work fine.
Just the trailer has issues.
Yep. The fuses are for the trailer lights only. The truck's signals will still work. If you pop the cover off the fuse box under the hood, I believe they are #16 and #17 fuses. One for left, and one for right. Edited by LowbanksArcher
Ok. I'll check it when I get home. Thanks.
  • 7 months later...
The left tail light on my 2015 silverado went out completely and when looking through the fuse diagram i am confused on which fuse i need to check to change. Please help guys. Thanks
Edited by Eber
Did you ever find a resolution for this? I have the same issue. All truck lights work except the passenger running light. The very same bulb works just fine when unlocking and locking. All fuses are ok. Plus almost none of my trailer lights work as well. Just the drivers side driving light. So if it's a bad ground, any idea where the ground is located?
Good place to check would be your adapter right in the bumper, depending on your location you might get some crud up in there. Another thing to try would be some CRC QD Electronic cleaner in the adapter with the truck OFF. Let it dry for 10 minutes and then try again.
  • 4 months later...
I have a 16 Silverado with the same problem there are 2 relays in the circuit board that controls each side for the brake and turn signal under the fuse box that if the fuse don't blow it will burn the relay up I just changed the whole fuse box out cost me $232 and about 10 minutes and I got mine working again. Chevrolet has a bulletin out about using cheap fuses causing a lot of trouble. If I can help with pictures message me. Also my camper had a short I used a cheap fuse and that's what took mine out.
That makes absolutely no sense
Last year My 2016 was towing a new boat and brother in laws 2015 was towing a new camper.
Both blew their fuses for the trailers lights during a rain storm down the highway at 65.
We yanked all the plugs and put di-electric grease in all connections.
Now blowing fuses for left rear trailer brake and turn signals in the 2015, in dry weather. We haven’t gone on a fishing-camping trip in the rain yet. But we both have a stockpile of fuses for this year now that we know its the TRUCKS electrical faults.
Both trucks all grounds to frame removed, cleaned, reinstalled and covered in di-electric grease.
It aint the boat or campers fault. GM’s.
Edited by Paintor
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
