Damn!!!!! You did a great job... I'm not gonna lie.. I was really looking at the photos to see if it was just another truck.. but looks legit.
Thanks, I really wanted to have it looking as clean as factory. My friend did a great job on the paint also. Im really happy with the outcome.
Edited by Dbeto54
Looks great... I will be doing the same to my 2014 sierra.. I am waiting on the fog lamps and a bit of time. Sierra upgrade to 2016 is less involved.... just bumper, grille, headlights,fog lights and radiator cover.
Edited by ricker6869
The taillights new are like $600 each, headlights for an LTZ about $800 each, for an LT about $600 each. Bumper $440, grill $600, lower valence with chrome insert adds up to about $450.
You saved a boatload if you did this with used parts.
I just wanted to do a simple LTZ swap on my truck and I was looking at over $1200 (excluding headlights).. I gave up.
Nice work! Now you STILL have a nicer truck than mine will ever be.
I just bought a 2016 LT Crew Cab. I too, thought all lighting was LED. When I saw the DRL come on LED, I was excited. Only to learn that the only LEDs in this trim level are the DRL and Fog. Turn signal, tail lights are incandescent. Would love to do this swap.
Nice conversion! I like the 2016s quite a bit though I do think your 15 had my favorite grill of the 14-15s. But still a nice change!
2015 Silverado to 2016 conversion in progress
Edited by daort15
yeah it involves less, good luck or you set up, share some photos when your done ??
yeah it gets expensive if you go all new. Thanks I think just a colormatched will set your truck up. Its a nice color.
Thanks I really liked that grill aswell. Edited by Dbeto54
Here are some pics of lighting, everything functions as factory.
All lights on
Fogs on
Turn signal while switchback
Edited by Dbeto54
Dbeto54 - This is slick! I'm sure inquiring minds (including myself) will want to intel on what it took to get everything to work. I have a 2016 Crew Cab LT and didn't know there was a difference with the Tail Lights and Head Lights until it was too late! What was the wiring like to get this to all work like factory?
Any updates on this?? I'm sure everyone would like to see how this can be done............
Personally, I'd trade mine before doing this. It's like the guys who changed their front clips to 2500's or Escalades. Any worries you are creating a Frankenstein that you will never be able to trade or sell?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
